ASUS SD554-YB commercial displays feature a built-in multimedia player that automatically detects and plays a variety of commonly used media file formats. The SD554-YB supports Full HD 1920 x 1080 content and features a 178-degree wide-view angle panel that provides stunning images even when viewed from extreme angles. SD554-YB features brightness of 350 cd/m2, making them ideal for indoor wall-mounted, shelved, or end-cap installations. The SD554-YB also has built-in speakers that provide clear audio to accompany the visuals. With everything housed in a single unit, the SD554-YBs ' all-in-one design makes it ideal for small businesses. It is a cost-effective solution that is easy to set up too, giving users a high return on investment.
Simply insert an USB storage device to the embedded media player for cable-free playback. It eliminates the need for a connection to a PC or other multimedia device. The all-in-one design of the SD554-YB ensures quick and easy set up.
The SD554-YB can automatically detect and play files from an USB drive. It supports various video, audio, and image file formats to give users more options when it comes to creating display materials.
Seamless vision for impactful messaging
ASUS SD554-YB commercial displays feature a built-in multimedia player that automatically detects and plays a variety of commonly used media file formats. The SD554-YB supports Full HD 1920 x 1080 content and features a 178-degree wide-view angle panel that provides stunning images even when viewed from extreme angles. SD554-YB features brightness of 350 cd/m2, making them ideal for indoor wall-mounted, shelved, or end-cap installations. The SD554-YB also has built-in speakers that provide clear audio to accompany the visuals. With everything housed in a single unit, the SD554-YBs ' all-in-one design makes it ideal for small businesses. It is a cost-effective solution that is easy to set up too, giving users a high return on investment. -
Easy, cable-free set up
Simply insert an USB storage device to the embedded media player for cable-free playback. It eliminates the need for a connection to a PC or other multimedia device. The all-in-one design of the SD554-YB ensures quick and easy set up. -
Plug and Play capabilities with diverse multimedia format support
The SD554-YB can automatically detect and play files from an USB drive. It supports various video, audio, and image file formats to give users more options when it comes to creating display materials. -
Vivid visuals even from extreme angles
The SD554-YB features a 178° wide-viewing angle display that eliminates color shift even when viewed from extreme horizontal or vertical angles. This means the audience experiences no image distortion or degradation even when they're viewing the screen from different angles. For added placement flexibility, the SD554-YB can be used in a portrait or landscape orientation. -
Powerful built-in speakers
SD554-YB features built-in twin 7 W speakers to provide quality audio to accompany what's onscreen. Situated at the rear of the display, the speakers eliminate the need for external speakers while maintaining the streamlined profile of the SD554-YB display.
- ASUS SD554-YB 55" LED-backlit LCD display - Full HD
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15)
- Technology
- AH-IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, 2 AAA batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.5 Watt
- 126.5 cm x 4.3 cm x 73.6 cm
- 21.2 kg
- Product Type
- Diagonal Class
- 55"
- Commercial Use
- TV Tuner Presence
- No
- Video Interface
- Component
- PC Interface
- DVI, VGA (HD-15)
- 126.5 cm
- 4.3 cm
- 73.6 cm
- 21.2 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AH-IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.63mm
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- Supported Video Formats
- MPEG-4, AVI, MOV, MPG
- Supported Audio Formats
- MP3, WMA, AC3, AAC, M4A
- Supported Pictures Formats
- BMP, JPG, GIF
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Speakers
- 1 x left channel speaker - 7 Watt , 1 x right channel speaker - 7 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- VGA input - rear , Audio line-in - side , Component video input - rear , Infrared input - side , Infrared output - side , USB 2.0 - side , Audio input - side , Audio output - side , DVI-D input - rear , SPDIF output - side , LAN - rear , Serial input , Serial output
- 2 AAA batteries
- Cables Included
- VGA cable - 1.8 m
- Plug and Play
- Power Device
- Power adapter
- Input Voltage
- 0.5 Watt
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
