Asus SD424-YB 42" 1920x1080 6.5ms VGA DVI HDMI LFD
Quicklinx: BJKWWS00 Mfr#: SD424-YB
  • 1080p
ASUS SD424-YB commercial displays feature a built-in multimedia player that automatically detects and plays a variety of commonly used media file formats. The SD424-YB supports up to full HD 1920 x 1080 content and features a 178-degree wide-view angle panel that provides stunning images even when viewed from extreme angles. SD424-YB features brightness of 350 cd/m2, making them ideal for indoor wall-mounted, shelved, or end-cap installations. The SD424-YB also has built-in speakers that provide clear audio to accompany the visuals. With everything housed in a single unit, the SD424-YBs' all-in-one design makes it ideal for small businesses. It is a cost-effective solution that is easy to set up too, giving users a high return on investment.
Simply insert an USB storage device to the embedded media player for cable-free playback. It eliminates the need for a connection to a PC or other multimedia device. The all-in-one design of the SD424-YB ensures quick and easy set up.
The SD424-YB can automatically detect and play files from an USB drive. It supports various video, audio, and image file formats to give users more options when it comes to creating display materials.
ASUS SD424-YB 42" LED-backlit LCD display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
42"
Commercial Use
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component
LAN
PC Interface
DVI, VGA (HD-15)
AH-IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Speaker System
2 speakers
USB
Remote control, 2 AAA batteries
Voltage
Power Consumption Stand by
0.5 Watt
98 cm x 3.9 cm x 57.3 cm
11.5 kg
Diagonal Class
42"
Commercial Use
TV Tuner Presence
No
Video Interface
Component
PC Interface
DVI, VGA (HD-15)
98 cm
3.9 cm
57.3 cm
11.5 kg
Enclosure Colour
Display
LCD Display Technology
AH-IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.4845 mm
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
Supported Video Formats
MPEG-4, AVI, MOV, MPG
Supported Audio Formats
MP3, WMA, AC3, AAC, M4A
Supported Pictures Formats
BMP, JPG, GIF
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Speakers
1 x left channel speaker - 7 Watt , 1 x right channel speaker - 7 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
VGA input - rear , Audio line-in - side , Component video input - rear , Infrared input - side , Infrared output - side , USB 2.0 - side , Audio input - side , Audio output - side , DVI-D input - rear , SPDIF output - side , LAN - rear , Serial input , Serial output
2 AAA batteries
VGA cable - 1.8 m
Plug and Play
Power adapter
Input Voltage
0.5 Watt
5 °C
20 - 80% (non-condensing)
