ASUS SD424-YB commercial displays feature a built-in multimedia player that automatically detects and plays a variety of commonly used media file formats. The SD424-YB supports up to full HD 1920 x 1080 content and features a 178-degree wide-view angle panel that provides stunning images even when viewed from extreme angles. SD424-YB features brightness of 350 cd/m2, making them ideal for indoor wall-mounted, shelved, or end-cap installations. The SD424-YB also has built-in speakers that provide clear audio to accompany the visuals. With everything housed in a single unit, the SD424-YBs' all-in-one design makes it ideal for small businesses. It is a cost-effective solution that is easy to set up too, giving users a high return on investment.
Simply insert an USB storage device to the embedded media player for cable-free playback. It eliminates the need for a connection to a PC or other multimedia device. The all-in-one design of the SD424-YB ensures quick and easy set up.
The SD424-YB can automatically detect and play files from an USB drive. It supports various video, audio, and image file formats to give users more options when it comes to creating display materials.
- ASUS SD424-YB 42" LED-backlit LCD display - Full HD
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Commercial Use
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15)
- Technology
- AH-IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, 2 AAA batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.5 Watt
- 98 cm x 3.9 cm x 57.3 cm
- 11.5 kg
- Product Type
- Diagonal Class
- 42"
- Commercial Use
- TV Tuner Presence
- No
- Video Interface
- Component
- PC Interface
- DVI, VGA (HD-15)
- 98 cm
- 3.9 cm
- 57.3 cm
- 11.5 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AH-IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.4845 mm
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- Supported Video Formats
- MPEG-4, AVI, MOV, MPG
- Supported Audio Formats
- MP3, WMA, AC3, AAC, M4A
- Supported Pictures Formats
- BMP, JPG, GIF
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Speakers
- 1 x left channel speaker - 7 Watt , 1 x right channel speaker - 7 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- VGA input - rear , Audio line-in - side , Component video input - rear , Infrared input - side , Infrared output - side , USB 2.0 - side , Audio input - side , Audio output - side , DVI-D input - rear , SPDIF output - side , LAN - rear , Serial input , Serial output
- 2 AAA batteries
- Cables Included
- VGA cable - 1.8 m
- Plug and Play
- Power Device
- Power adapter
- Input Voltage
- 0.5 Watt
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
