The 21.5-inch SD222-YA is a regular monitor that features its own multimedia player, making it ideal for use as a digital signage. Simply plug in an SD card or USB storage device to the SD222-YA for cable-free content playback. It is wall-mountable and has a unique foldable stand which folds within the monitor when not in use.
Impressive visuals
LED-backlit AH-IPS panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. Full HD 1920 x 1080 resolution, 1000:1 contrast ratio, and 250 cd/m2 brightness delivers extreme image clarity and excellent color reproduction. -
Ergonomic design
The SD222-YA is wall-mountable and has a unique foldable stand which folds within the monitor when not in use. This minimal-fuss design features no screws, and can be easily set-up in minutes. -
Eco-friendly features
Mercury-free LED-backlit panel, corrugated cardboard packaging with at least 80% recycled content. Lower power consumption means energy savings to increase overall ROI.
- ASUS SD222-YA 21.5" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 21.5"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Supported Memory Cards
- SDXC Memory Card
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 37 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 51.8 cm x 5.5 cm x 31 cm
- Product Type
- 37 Watt
- Diagonal Class
- 21.5"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- PC Interface
- VGA (HD-15)
- Dimensions
- Without stand
- 51.8 cm
- 5.5 cm
- 31 cm
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1000:1
- Brightness
- 250 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 5 ms
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 100 x 100 mm
Media Player
- Supported Video Formats
- MPEG-1, MPEG-4, Xvid, WMV, ASF, AVI, MKV, MOV, VOB, IFO, FLV, TS, M2TS, RMVB, M4V, TRP
- Supported Audio Formats
- MP3, WAV, AC3, AAC, Ogg Vorbis, AIFF, FLAC (Free Lossless Audio Codec)
- Supported Pictures Formats
- BMP, JPG, GIF, TIFF, PNG
- SDXC Memory Card
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Speakers
- 1 x left channel speaker - 3 Watt , 1 x right channel speaker - 3 Watt
- Connector Type
- VGA input - rear , Audio line-in - rear , Audio line-out - rear , USB 2.0 - side
- Plug and Play, UL, VCCI, C-Tick, BSMI, cUL, CB, CCC, FCC, GOST-R
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- No
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 51.8 cm x 5.5 cm x 31 cm , Panel with stand - 51.8 cm x 20 cm x 38.5 cm
