Asus SABERTOOTH Z87 S1150 Intel Z87 DDR3 ATX
Quicklinx: 8Q9JWS00 Mfr#: SABERTOOTH Z87
Asus Sabertooth Z87-Plus High Performance Z87 chipset mainboard, the Thermal Armor mainboard for the TUF.
Asus Sabertooth Z87 motherboard supports Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors in the LGA1150 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 MHz memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors are among the most powerful and energy efficient CPUs in the world.
The Intel® Z87 Express Chipset is a single-chipset design to support socket 1150 4th generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z87 chipset provides maximum 6 USB 3.0 ports and maximum 6 SATA 6Gb/s ports for faster data retrieval speed. Moreover, Intel® Z87 Express Chipset also supports iGPU function, letting users enjoy the latest Intel integrated graphic performance.
  • Fan Expert2 - customize Fan speeds
  • Digi+VRM - Precise Over Clocking
  • USB BIOS Flash Back - Easy Bios Updates
  • USB 3.0 Boost - Fast Data Transfer
  • EPU - Green Energy saving
  • New UEFI Bios Design.
  • TUF stands for The Ultimate Force
    The TUF series delivers a "tough" image. With the unique design and high quality components (military-standard), TUF series is born for pursuing the preeminent stability, all-round compatibility, and extreme durability.
  • Bolsters boards against bending damage
    TUF Fortifier adds a strong backplate so the motherboard doesn't buckle under the weight of heavy graphics cards and CPU coolers. Reduced PCB bowing and bending means an end to potentially damaged circuitry. With a thermal pad directing heat away from VRM and other key components, TUF Fortifier combines great strength and cooling.
  • Total airflow-boosting heat dissipation
    Covers the entire board and features dual fans to direct cool air to critical parts and dissipate heat faster for better stability. Drastically boosts airflow and cooling with dual fans and a smart shunt design that directs hot air away from critical components. Air power is improved with a back I/O fan that pulls in cold air and expels even more heat. Exclusive flow valve design controls heatpipe air contact, better-utilizing liquid cooling setups.
  • Complete system cooling, customized fan tuning
    With multiple onboard sensors and bundled thermistor cables, you can real-time monitor temperatures for areas around key components other than the motherboard itself. Customizable fan control gives you the flexibility of adjusting fan speeds manually and achieving optimal thermal tuning with one click.
  • Repel the dust, expand the lifespan
    TUF design protects back I/O ports, expansion and memory slots plus critical connectors from dust and particles that degrade system performance over time if left unchecked. With a filter to ensure the back I/O fan doesn't draw dust into the board, dust defender guards against dust build up, helping your PC perform in an optimal and stable state longer.
  • Certified for tough duty
    TUF metallic capacitors, chokes, and MOSFETs are screened by seven rigorous military-grade tests to ensure superior lifespan even under the most demanding conditions.
  • Full-scale performance tuning with easy BIOS interface
    Media-renowned UEFI BIOS from ASUS offers the first mouse-controlled graphical interface designed with a special theme for TUF boards, providing a user-friendly interface that goes beyond traditional keyboard-only controls. ASUS-exclusive EZ mode displays frequently-accessed info, so you can alter system performance settings and drag and drop boot priorities. Advanced mode for performance enthusiasts includes detailed DRAM settings via a dedicated memory info page for complete insight.
  • Dedicated direct BIOS access button
    Designed for those requiring frequent BIOS access, users can easily enter the BIOS when the PC is on standby power with a simple press of a button. It saves you time during boot-up as you don't have to repeatedly press the DEL key. Convenience and ease at their best!
  • 170% faster transfer speeds than traditional USB 3.0
    ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol) USB 3.0. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to already fast USB 3.0 performance. ASUS software automatically accelerates data rates for compatible USB 3.0 peripherals without any user interaction.
  • Discover future visual experiences
    Following up on popular 1080p Full HD, 4K Ultra HD is the next big thing, and you're ready for the upgrade thanks to integrated graphics that natively support up to 4096 x 2160 via HDMI or DisplayPort. That's four times the pixel count of 1080p (1920 x 1080), offering incredible visual clarity, detail, and realism.
ASUS SABERTOOTH Z87 - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600, 2 x eSATA-600
USB / FireWire Ports
4 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
5-year warranty
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Intel I217V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 3 x PCIe x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin SATA, 2 x 7pin eSATA - 4 devices
RAID Features
Intel Smart Response Technology
1 x DisplayPort , 1 x HDMI , 1 x TOSLINK , 4 x USB 2.0 , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Jack retasking, MemOK!, ASUS Q-Design, ESD Guards, TUF Engine!, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, ASUS Precision Tweaker 2, Intel Extreme Memory Profile (XMP) support, ASUS 8+2 Phase Power Design, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, Intel Clear Video HD Technology, Intel Smart Response Technology, USB 3.0 Boost, AMD Quad CrossFireX technology support, ASUS Network iControl, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Ultimate COOL!, TUF Dust Defender, ASUS Remote GO!, DirectKey, TUF Thermal Armor with Flow Valve, TUF Thermal Radar 2, TUF Fortifier
2 x 35mm fans, accessory package
1 x SLI bridge , 4 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Charger, ASUS CPU-Z, ASUS AI Suite III
Plug and Play, RoHS, ErP Ready, ACPI 5.0
30.5 cm
24.4 cm
Limited warranty - 5 years
