SABERTOOTH Z170 MARK 1 envisions futuristic fighting forces, with sleek, stealthy Thermal Armor to make a powerful statement of both high style and extreme strength.
Detachable metal TUF badge
Forged with a singular steel construction, a strong metal that channels courage - a symbol of your true being and everything you stand for. -
Q-LED indicators
With a design inspired by an armored cockpit, see the power and act on the alerts, with a clear indication of five key boot actions. -
Thermal Armor
TUF Thermal Armor is more than a futuristic shield: it employs dual fans to provide maximum airflow and rapid cooling board-wide, and an interior shunt design to boost air cooling to the M.2 slot. Reversible-airflow technology blows dust up and away from the heatsink VRM, while the exclusive flow-valve design controls the heat-pipe's air contact - great for liquid-cooling setups. -
TUF Fortifier improves rigidity and cooling behind the board
SABERTOOTH Z170 MARK 1 delivers great strength and cooling via exclusive TUF Fortifier. A reinforced backplate ensures that the motherboard doesn't buckle under the weight of heavy graphics cards and CPU coolers, minimizing the risk of damaged circuitry from bowing and bending. -
ASUS PRO Clock technology
A dedicated base-clock (BCLK) generator allows overclocked base clock frequencies. This custom solution works in tandem with the ASUS Turbo Processor Unit (TPU), to enhance voltage and base-clock overclocking control - granting an exciting way to boost performance to extreme heights. -
Media-acclaimed UEFI BIOS
Smoothes, slick mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, the EZ and advanced modes help you find your way, quickly and easily. -
The total cooling commander
ASUS TUF engineers have forged TUF ICe, a dedicated processor that monitors onboard temperature sensors and fan speeds for ultra-accurate cooling - whether you're adjusting settings manually or using the automatic one-click optimization. -
Thermal Radar 2 - instant fan tuning, complete system cooling
Thermal Radar 2 has 13 fan connectors and is able to connect with TUF Detective 2 wirelessly for fan control via your smartphone or tablet. Moreover, multiple onboard sensors and the bundled thermistor cable let you monitor graphics card temperatures and other key components in real time, so you can adjust manually or optimize automatically with one click. -
TUF Defenders
TUF design protects back I/O ports, expansion and memory slots, and prevents dust and other airborne particles from entering critical connectors. Dust Defenders guards against dust build up, helping your PC perform in an optimal and stable state for longer. -
Ultimate-speed 10 Gb/s with USB 3.1 onboard
With one USB 3.1 Type-A port and one reversible USB 3.1 Type-C for very fast USB connections, you'll experience data-transfer speeds of up to 10 Gbit/s - or twice as fast USB 3.0. USB 3.1 is completely backward-compatible with your existing USB devices, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 Boost technology automatically accelerates USB 3.1 performance even further! -
Turbo lan
Turbo LAN with cFosSpeed traffic-shaping technology adds even more lag-reducing support and intuitive user interface. It allows you to lower lag with no expert knowledge! If you're a tweaker, use advanced mode for hardcore controls. -
Audio shielding
Ensures precision analog/digital separation and qreatly reduced multi-lateral interference. -
Unique de-pop circuit
Reduces start-up popping noise to all audio outputs. -
Audio amplifier
Enhance high-quality sound for headphone and speakers. -
Special layout design
Separate layers for left and right channels to guard the quality of the sensitive audio signals.
- ASUS SABERTOOTH Z170 MARK 1 - motherboard - ATX - LGA1151 Socket - Z170
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 2 x SATA-600, 2 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 2 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 512 MB
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2400 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 512 MB
Audio
- Audio Codec
- Realtek ALC1150
LAN
- Network Controller
- Intel I219V / Realtek RTL8111H
- Network Interfaces
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 3 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 2 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
- RAID Features
- Intel Rapid Storage Technology
- 1 x DisplayPort , 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x USB 3.1 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 4 x USB 2.0 , 1 x USB-C , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x SPDIF out - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, TUF Engine!, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, ASUS Q-Connector, ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, Intel Turbo Boost Technology 2.0, TUF Thermal Armor, Intel Clear Video HD Technology, Intel Smart Response Technology, Q-Code, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, 8+4 Phase Power Design, Ultimate COOL!, Safe & Stable! Guardian Angel, TUF Dust Defender, Disk Unlocker, TUF Thermal Radar 2, TUF Fortifier, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), Turbo LAN, LANGuard, TUF ICe, USB 3.1 Boost, TUF ESD Guards 2, ASUS Crystal Sound 3, ASUS PRO Clock Technology, TUF Detective 2, TUF Components
- Included Accessories
- I/O back plate, accessory package, 35/40mm fans, 1 x M.2 screw, M.2 X4 bracket
- Cables Included
- 4 x Serial ATA cable , 1 x SLI bridge
- Software Included
- Drivers & Utilities, ASUS AI Charger, ASUS AI Charger+, ASUS AI Suite III, PC Cleaner
- Plug and Play
- 30.5 cm
- 24.4 cm
- Limited warranty - 5 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
