Your basket is empty
Asus SABERTOOTH X99 LGA-2011v3 Intel X99 USB 3.1 Boost
Quicklinx: B7N2WS00 Mfr#: SABERTOOTH X99
Processor Socket: LGA2011-v3 Socket
Chipset: Intel X99 Express
Graphics: None
Form Factor: ATX
Memory Support: DDR4 SDRAM
£256.18 ex VAT
£307.41 inc VAT
Designed to break performance barriers, ASUS OC Socket utilizes extra pins to connect a proprietary circuit to contacts found on Haswell-E's land grid array (LGA). This feature enables higher DDR4 memory frequencies, lower latencies and enhanced stability while overclocking, extending all the way to extreme overclocking conditions, such as Liquid Nitrogen (LN2). Cache bus links areas such as CPU cores, DDR4 Memory Controllers, System Agent and the shared L3 Cache. It is a critical interconnect for the whole CPU subsystem. Higher cache bus frequency directly gives faster total sub-system performance. ASUS OC Socket exclusively provides an adjustable cache bus voltage to reach higher cache bus frequencies.
This is a platform to support DDR4 memory and it's able to drive memory frequencies to 3200MHz (and beyond when overclocked)! ASUS-exclusive T-Topology circuit design plus OC Socket provides superb memory-overclocking capability to unleash the full power of DDR4 by minimizing coupling noise and signal reflection. More than just a cool military-styled cover, TUF Thermal Armor employs the fan to provide boosted airflow for rapid cooling. The special heat pipes accelerate dissipation from critical components and make sure temperatures stay low across the board. SABERTOOTH X99 Thermal Armor can reduce the temperature by up to 10°C!
SABERTOOTH X99 Thermal Radar 2 now has up to 11 fan connectors to let you control fans as many as you want. Moreover, Multiple onboard sensors and the bundled thermistor cable let you monitor graphics card temperatures and other key components in real time, so you can adjust manually or optimize automatically with one click.
ASUS SABERTOOTH X99 - motherboard - ATX - LGA2011-v3 Socket - X99
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7, Xeon E5-2600 v3 series, Xeon E5-1600 v3 series
Max RAM Size
64 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
2 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Graphics
No graphics
Audio
HD Audio (8-channel)
LAN
2 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Quad channel memory architecture
Graphics
Graphics Controller
No graphics
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Intel I218V / Realtek 8111GR
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode) , 1 x M.2 socket
Storage Interfaces
SATA-600 -connectors: 8 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
2 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 2 x USB 3.1 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x audio - header , 1 x serial - header , 1 x SPDIF out - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
MemOK!, 8+2 Phase Power Design, TUF Engine!, CrashFree BIOS 3, ASUS Q-Connector, ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, TUF Thermal Armor, Loss-less content protection technology, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Ultimate COOL!, TUF Dust Defender, TUF Thermal Radar 2, TUF Fortifier, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), Clear CMOS Button, anti-pop function, Turbo LAN, TUF ICe, Intel Rapid Recovery Technology, ASUS OC Socket, TUF ESD Guards 2
Dust covers
1 x 3-way SLI bridge , 6 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS CPU-Z, Antivirus (OEM version)
Plug and Play, ACPI 5.0
30.5 cm
24.4 cm
Graphics: None
Form Factor: ATX
Brand: Asus
Price Range Ex VAT: 150 - 300
