ASUS TUF Z270 Mark 1 LGA1151 DDR4 DP HDMI M.2 USB 3.1 Z270 ATX Motherboard
- Designed for 7th generation LGA1151 socket Intel® Core™ processors to maximize connectivity and speed with integrated Dual M.2 with Intel® Optane™ Memory compatibility, front panel USB 3.0 and rear USB 3.1 Type-A / Type-C connections
- AURA Sync RGB lighting features a nearly endless spectrum of colors with the ability to synchronize effects across an ever-expanding ecosystem of AURA Sync enabled products
- Dual Patent-pending SafeSlots featuring an injection molding process that integrates metal framing for a stronger, firmly anchored PCIe slot built for heavyweight GPUs
- Thermal Armor protective shielding and TUF Fortifier backplate for ducted cooling and structural rigidity
- Ultimate Protection with Thermal Radar 2 PLUS for customizable total system cooling and a 5-Year Warranty for guaranteed reliability built on Military Grade engineering
ASUS Aura Sync technology for distinctive lighting effects
Aura Sync takes RGB lighting beyond the checkbox, combining and controlling the LEDs of your Aura-enabled products from a single application - so you can achieve perfect, synchronized lighting harmony. Aura lets you sync light effects across your graphics card, TUF Z270 Mark 1 motherboard, and an ever-growing portfolio of Aura-enabled products. -
Overclocking design
Implementing an engineering-intensive DRAM layout, the ASUS T-Topology delivers DDR4-overclocking dynamics, that let you push memory frequencies further than ever - all the way if all memory slots are being utilized!
- ASUS TUF Z270 MARK 1 - motherboard - ATX - LGA1151 Socket - Z270
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 2 x M.2
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 2 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1 GB
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1 GB
Audio
- Audio Codec
- Realtek ALCS1220A
- DTS Connect, High Definition Audio, DTS Headphone:X
LAN
- Network Controller
- Intel I219V / I211
- Network Interfaces
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 3 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
- RAID Features
- Intel Rapid Storage Technology
- 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 1 x USB 3.1 , 2 x USB 3.0 , 4 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK , 1 x USB-C , 1 x DisplayPort
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header , 1 x audio - header , 1 x Thunderbolt - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS O.C. Profile, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, ASUS Q-Design, TUF Engine!, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), TUF Thermal Armor, Intel Smart Response Technology, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Ultimate COOL!, Safe & Stable! Guardian Angel, TUF Dust Defender, TUF Fortifier, ASUS O.C. Tuner, Turbo LAN, TUF ICe, Memory O.C. Design, TUF ESD Guards 2, TUF LANGuard, ASUS Crystal Sound 3, ASUS PRO Clock Technology, TUF Detective 2, TUF Components, AURA RGB Lighting Control, Intel Optane Memory Ready, ASUS 8 + 4 Digital Phase Power Design, TUF Thermal Radar 2+
- Included Accessories
- Accessory package, 1 x M.2 screw, I/O back cover, TUF stickers, vertical M.2 bracket set
- Cables Included
- 4 x Serial ATA cable , 1 x SLI bridge
- Software Included
- Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS Turbo App, PC Cleaner, ASUS EZ Flash 3, Cloud GO!
- Plug and Play
- 30.5 cm
- 24.4 cm
