Asus SABERTOOTH 990FX R3.0 AM3+ 990FX DDR3 M.2 USB3.1 ATX
Quicklinx: C9DVWS00 Mfr#: SABERTOOTH 990FX R3.0
The TUF series delivers a "tough" image. With the unique design & high quality components (military-standard), TUF series is born for pursuing the preeminent stability, all-round compatibility, and extreme durability.
  • Innovative and creative
    Sabertooth 990FX R3.0 drives ASUS TUF's direct-etching concept forward by military-inspired digital pattern directly onto the board in commanding gun-metal grey! As unique as it is evocative of might, Sabertooth 990FX R3.0's stunning aesthetic envisions the future for your next battle-ready rig.
  • Brighten up your build
    ASUS Aura offers full RGB control with a variety of exciting presets for its onboard LED illumination, all of which can be synced with an ever-growing portfolio of Aura-capable ASUS hardware.
  • Reinvented SafeSlot
    SafeSlot is the PCIe slot reinvented by ASUS and engineered to provide superior retention and shearing resistance which protect your graphics card investment. Manufactured in a single step using a developed injection-molding process integrates the slot with the fortifying metal for an inherently stronger slot, which is then firmly anchored to the PCB through additional solder points.
  • Q-LED indicators
    With a design inspired by an armored cockpit, see the power and act on the alerts, with a clear indication of five vital boot actions.
  • Strong protection with airflow-boosting potential
    Sabertooth 990FX R3.0's connectivity ports are protected by strong armor that also looks just great. And, if you fit an additional fan, the port armor boosts airflow for the best possible cooling - with temperature reductions of up to 11°C!
  • Thermal Radar 2
    Thermal Radar 2 lets you control fans on ASUS graphics cards, as well your case fans! Multiple onboard sensors also let you monitor temperatures onboard and other key components in real time, so you can adjust manually or optimize automatically with one click.
  • TUF LANGuard - Intel Gigabit LAN
    Sabertooth 990FX R3.0 is engineered with state-of-the-art Intel Gigabit Ethernet for super-fast networking at up to 1 Gpbs, and protected by TUF LANGuard: this military-grade innovation integrates advanced signal-coupling technology and premium surface-mounted capacitors to improve throughput - protecting Sabertooth 990FX R3.0 from lightning strikes and static electricity.
  • Audio connectors
    Capacitor protection on both front and back audio-output circuits.
  • LAN port
    ESD TVS diode protection on the LAN circuit bolstered by an anti-surge LAN connector that increases protection against extreme events, such as lightning strikes.
  • Ultimate-speed 10 Gb/s with USB 3.1 onboard
    With three USB 3.1 Type-A ports for complete backward-compatibility with existing USB devices and one reversible 3.1 Type-C for any-way-up convenience, you're all ready for breakneck speeds of up to 10 Gbps - or twice as fast USB 3.0. And ASUS USB 3.1 Boost technology automatically accelerates USB 3.1 performance even further!
  • Turbo LAN
    Turbo LAN with cFosSpeed traffic-shaping technology adds even more lag-reducing support and intuitive user interface. It allows you to lower lag with no expert knowledge - by up to 1.45x!
  • TUF Audio Design
    TUF Audio Design makes short work of optimizing audio settings for the way you want to listen, chatting, watching movies or relaxing to your favorite music. Onboard physical shielding, professional engineered design and premium components result in sound output that has exceptional clarity and fidelity.
ASUS TUF SABERTOOTH 990FX - 3.0 - motherboard - ATX - Socket AM3+ - AMD 990FX
Motherboard - ATX
Chipset Type
AMD 990FX / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Sempron X2, Phenom II X4, Phenom II X6, FX (supports CPUs with up to 8 cores, Maximum TDP 220 Watt)
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, ECC, unbuffered
Storage Ports
5 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
1 x USB-C + 3 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Intel I211
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 2.0 x16 (dual x16 mode; triple: x16, x8, x8 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1
Storage Interfaces
AMD SB950: SATA-600 -connectors: 5 x 7pin SATA - 5 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , AMD SB950: SATA-600 / PCIe -connectors: 1 x M.2 - 1 devices
1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 4 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x USB-C , 3 x USB 3.1
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
AMD Cool 'n' Quiet Technology, jack retasking, MemOK!, ASUS Q-Design, TUF Engine!, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, ASUS Precision Tweaker 2, NVIDIA 3-way SLI Technology Support, ASUS 8+2 Phase Power Design, NVIDIA Quad SLI Technology Support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Ultimate COOL!, Hyper Transport 3.0, TUF Thermal Radar 2, Preboot eXecution Environment (PXE), Turbo LAN, USB 3.1 Boost, TUF ESD Guards 2, TUF LANGuard, TUF Components, AURA RGB Lighting Control, ASUS SafeSlot
I/O back cover, TUF stickers
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS EZ Flash 2, ASUS Update, ASUS AI Suite III, Antivirus (OEM version), Media Streamer
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
