ROG Strix GL702ZC is the gaming laptop, featuring excellent processor. Combining the sheer power of improved platform with ROG's gaming design legacy, ROG Strix GL702ZC is designed to deliver amazing performance to satisfy the needs of hard-core gamers and users with demanding, multimedia-heavy workloads. With a 17.3-inch, wide-view panel for incredible visuals, an anti-ghosting backlit keyboard for fast, accurate control and a wealth of gamer-oriented features, ROG Strix GL702ZC is a finely tuned weapon, backed by the power for gaming a competitive edge.
Unprecedented computing power
Experience ultimate computing power with the excellent processor and graphics card. Together with the Zen microarchitecture with simultaneous multithreading technology (SMT) and SenseMI technology, that intelligently optimizes performance and energy consumption, the processor delivers stand-out performance, that enables ROG Strix GL702ZC to outpace the competition. -
Stunning wide-view panel with AMD FreeSync
ROG Strix GL702ZC is equipped with a wide-view panel, that supports AMD FreeSync display technology for fast-paced games. AMD FreeSync synchronizes the display's refresh rate with the graphics card to prevent lag, minimize frame-rate stutter and eliminate visual tearing for ultra-smooth visuals. ROG Strix GL702ZC even works with AMD FreeSync-supported external monitors via DisplayPort or HDMI, letting you enjoy the smooth and fast gaming graphics performance with maximum flexibility. -
Immersive virtual reality
The improved GPU boosts speed and power efficiency for brilliant virtual-reality performance, letting you enjoy smooth, low-latency, and stutter-free VR experiences. -
A keyboard, designed for gaming
The tactile gaming keyboard on ROG Strix GL702ZC also features stylish backlighting, specially designed WASD keys, and an optimal key travel distance. Their engineering team performs meticulous keyboard tests, ensuring ultimate durability and reliability with a long expected lifetime. ROG Strix GL702ZC will arm you with a keyboard, that you can trust. -
Intelligent thermal design
The Hyper Cool Duo-Copper cooling system uses heat pipes and a dual fan system to cool the CPU and GPU independently. This design maximizes cooling efficiency to give ROG Strix GL702ZC the stability, required for intense gaming marathons. -
Filter out all ambient noise
ROG Strix GL702ZC offers the array microphones, designed to filter out ambient noise, so your voice will come through loud and clear, which means, that even if you're at a LAN party or in another loud environment, your voice will come through loud and clear. -
Sonic Studio and Sonic Radar
Sonic Studio and Sonic Radar deliver immersive gaming audio. Sonic Studio provides high-quality in-game audio, as well as improved streaming and audio recording for perfect voice pickup and noise reduction. Sonic Radar helps you detect opponents through an on-screen overlay, that shows the relative position of gunshots, footsteps and other in-game sound effects.
- ASUS ROG Strix GL702ZC GC104T - 17.3" - AMD Ryzen 7 - 1700 - 16 GB RAM - 256 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- AMD Ryzen 7 1700 / 3 GHz, up to 3.7 GHz
- Memory
- 16 GB DDR4
- Storage
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon RX 580
- Video Memory
- 4 GB
- VR Ready
- Gaming
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell
- 41.5 cm x 28 cm x 2.4 cm
- 3.2 kg
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- 8-core
- 64-bit Computing
- Chipset
- AMD B350
- RAM
- 16 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD M.2
- Secondary Storage
- 1 TB HDD SATA
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- WideView, FreeSync Technology
Audio & Video
- Graphics Processor
- AMD Radeon RX 580
- Video Memory
- 4 GB
- VR Ready
- Gaming
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Numeric Keypad
- Anti-ghosting
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell
- Capacity
- 76 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 280 Watt, 19.5 V, 14.36 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , Mini DisplayPort , HDMI , 3 x USB 3.1 Gen 1 , LAN , USB-C 3.1 Gen 2
- Memory Card Reader
Software
- Software Included
- ASUS ROG Gaming Center
- Included Accessories
- Power adapter
- UL, TUV, BSMI, CCC, FCC, WEEE, ErP 2013
- 3.2 kg
Sustainability Information
- TCO Certified
