Product
Brand
Asus RT-N12E N300 300Mbps Eco Series Wireless Router
Quicklinx: 8KZ9WS00 Mfr#: RT-N12E
  • IEEE 802.11n
ASUS RT-N12E supports 802.11 b/g/n and has 300 Mbps high speed. With CD free easy installation and stable data transmission, RT-N12E is the basic solution for wireless internet setup. It also contents Green WLAN technology so it consumes less power during stand by mode.
Save the planet and your pocket
Compared with generic Wireless-N routers, ASUS ECO-WiFi CPU reduces 72%* of energy consumption and utility cost.
* The result given was of an internal testing methods comparing typical router, with standby, normal and heavy traffic. Testing criteria: [Standby mode] Only WAN ports are connected. [Normal traffic] 1 wired connected PC and 1 wirelessly connected laptop for P2P download. [Heavy traffic] 4 wired connected PCs and 2 wirelessly connected laptops for P2P download. Utility cost is calculated based on 2011 US household avg. electricity price, all taxes included.
Extended Network Coverage
The RT-N12E features a 2 x 2dBi high-gain antennas that boosts the wireless signal, thereby extending coverage range.
*Antenna type will differ according to local regulations and requirement in each country.
Network Map-Manual Free Management - Straight-forward design to help users to:
Display the whole network status and clearly provide WAN/LAN status
Securely connect to your wireless network and prevent intruders from using it
Manage your network in minutes
Try our EZ UI software
WPS Function& WPA/WPA2 Encryption
WEP encryption is not enough for Wi-Fi connection nowadays, and intruders may access your Internet flagrantly. Using WPS function and WPA/WPA2 encryption can firmly secure your home networks and protect the private resources.
Plug-n-Surf Installation
3-steps is all you need to set up the router. You don't need a CD for installation.
Step1:
Power up the router and launch the browser
Step2:
Enter the information provided by your ISP
Step3:
Start surfing!
Header / Manufacturer
ASUSTeK COMPUTER
Header / Product Line
ASUS
Wireless router
Header / Model
RT-N12 LX
Header / Packaged Quantity
1
Networking / WAN Ports Qty
1
Miscellaneous / Encryption Algorithm
128-bit WEP, 64-bit WEP, MPPE, WPA-Enterprise, WPA-PSK, WPA2-Enterprise, WPA2-PSK
Dimensions & Weight / Depth
16.8 cm
Dimensions & Weight / Weight
210 g
Dimensions & Weight / Height
3 cm
Speed
300 Mbps
Networking / Integrated Switch
4-port switch
Networking / Wireless Protocol
802.11b/g/n
Networking / Form Factor (FE)
Desktop
Networking / Network / Transport Protocol
DHCP, IPSec, L2TP, PPPoE, PPTP
Standards
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Header / Compatibility
PC
Networking / Connectivity Technology
Wired, Wireless
Dimensions & Weight / Width
12.4 cm
