The ASUS RT-AC68U is the Wi-Fi router, with combined dual-band data rates of up to 1900 Mbps. 1300 Mbps 802.11ac at 5 GHz gives Gigabit wireless data rates, while Broadcom TurboQAM technology super-charges 2.4 GHz 802.11n performance from 450 Mbps to 600 Mbps with compatible devices.
Powered by a dual-core processor, the RT-AC68U eliminates the performance drops that plague other routers with busy networks. So even on the busiest home networks, HD video streaming is always smooth, the latency low for online gaming and VoIP calls, and file downloads are never interrupted.
The RT-AC68U also features dual USB ports for file, printers and 3G/4G modems sharing and a USB 3.0 port for up to ten times faster data transfers than USB 2.0. ExclusiveASUS AiCloud transforms your home networking into your personal cloud for easy streaming and sharing to smartphones, PCs, and tablets. Router-to-router sync also makes it simple to sync files on USB-connected storage with other compatible ASUS routers for hassle-free sharing of large files with family and friends.
The easy-to-use ASUSWRT graphical user interface unlocks the power of the RT-AC68U giving robust control to optimize your network for you. 30-second set-up and easy traffic management means even network newbies can enjoy its sophisticated features, while power users will love its IPv6 support, multiple wireless SSIDs and secure VPN access.
AiProtection with Trend Micro for advanced security
AiProtection, incorporating state-of-the-art, three-pronged security from Trend Micro, provides advanced parental controls, blocks malicious addresses and intrusions for your PC or device, and alerts you if an infected device is connected. Potential weaknesses such as password strength and operating system vulnerabilities are also monitored at all times. Moreover, AiProtection even protects Wi-Fi devices without an installable security program such as smart TV, game console, and smart home devices, giving you peace of mind. -
Super-fast AC Wi-Fi with TurboQAM Wi-Fi acceleration
Powered by 5th generation Wi-Fi (5G Wi-Fi), the new 802.11ac chipset gives the RT-AC68U superfast Gigabit wireless speeds. What's more, RT-AC68U uses TurboQAM technology to upgrade 2.4G Wi-Fi even further to give you unprecedented speeds. At 2.4 GHz, it's 33% faster than generic wireless-N900 routers, reaching 600 Mbps, while on the 5 GHz band it blazes to 1300 Mbps - or triple 802.11n rates. That's 1900 Mbps of concurrent wireless power! -
Do more at once with dual-core processors inside
The ASUS RT-AC68U features a dual-core processor that eliminates the performance drops that plague other routers. So even on the busiest home networks, HD video streaming is always smooth, the latency low for online gaming and VoIP calls, and file downloads are never interrupted. -
Enhanced signal range and stability
ASUS AiRadar intelligently strengthens wireless connectivity using beamforming technology, high power amplification, and exclusive ASUS RF fine-tuning. This ensures extended coverage, dynamic data speed increases, and enhanced stability. -
Dual-band connectivity for compatibility and performance
Delivering 2.4 GHz and 5 GHz concurrent bands at up to 600 Mbps and 1300 Mbps, respectively, the RT-AC68U has a total speed of up to 1900 Mbps, and maintains complete stability. You can perform basic tasks like Web browsing and file downloading on the 2.4 GHz band, while simultaneously allowing multiple devices to stream in Full HD or support online gaming and other bandwidth-demanding applications smoothly on the clearer 5 GHz band. -
Ultimate USB speed and versatility
Highest Speed USB 3.0 features data transfers up ten times faster than USB 2.0. Two USB ports make the RT-AC68U perfect for file, multimedia, and 3G/4G sharing, while ASUS AiDisk offers remote access and quick content streaming. Where other routers have their USB ports sandwiched next to one another, both RT-AC68U USB ports are evenly spaced for easy access to either at all times. -
Dedicated Wi-Fi for your visitors
Share your internet connection with your guests with no need to share your personal password or network resources. ASUS Guest Network supports up to three separate guest networks, each with its own usage limits and password. Guests cannot access your primary network or any other connected devices.
- ASUS RT-AC68U - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1900 Mbps
- Capacity
- Guest networks: 6
- TCP/IP, PPTP, L2TP, NTP, IPSec, PPPoE, LPR/LPD, DHCP, DDNS
- Routing Protocol
- IGMP, static IP routing
- Network monitoring, VPN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, print server, MAC address filtering, IPv6 support, URL filtering, parental control, IP address filtering, P2P client, download client, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, Samba support, FTP server, Multiple SSID support, static IP mode, DNS proxy, ASUS AiDisk, UPnP Media Server, bandwidth control, port triggering, 3G/4G USB Dongle Support, dynamic IP mode, Traffic Control, ASUS Universal repeater, Multicast Proxy support, VPN Server, ASUS AiCloud, Multicast Rate Setting support, ASUSWRT, Broadcom TurboQAM technology
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- 22 cm x 16 cm x 8.28 cm
- 635 g
- System Requirements
- Linux, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Apple MacOS X, Apple MacOS X 10.1, Microsoft Windows Server 2003, Apple MacOS X 10.4, Apple MacOS X 10.6, Microsoft Windows Server 2008, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- 2-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1900 Mbps
- Capacity
- Guest networks: 6
- Routing Protocol
- Encryption Algorithm
- MPPE, 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Processor
- Broadcom
- Status Indicators
- Power, WAN, LAN, wireless, USB
- WAN: 1 x 1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- Voltage Required
- Cables Included
- 1 x network cable
- Software Included
- Drivers & Utilities
- OS Required
- 22 cm
- 16 cm
- 8.28 cm
- 635 g
- Limited warranty - parts and labour - 2 years
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
