Asus ROG Zephyrus S 15.6" Core i7-8750H 16GB 512GB SSD RTX 2070
Quicklinx: FDDQWS00 Mfr#: GX531GW-ES008R
Display Size: 15.6in
Processor Model: I7-8750H
Operating System: Windows 10 Pro, Windows 10 Pro
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i7
£2,506.12 ex VAT
£3,007.34 inc VAT
After redefining ultra-slim gaming laptops with the original Zephyrus, ROG brings hardcore gaming to an even thinner design framed by super-narrow bezels. ROG Zephyrus S uses innovative engineering to cool its powerful processor and GPU with Max-Q design, so you can immerse yourself in its no-compromise display.
  • Ultraportable gaming
    Clever design and expert craftsmanship are required to put high-end chips into the slimmest gaming laptop ever. Extremely thin, the metal chassis and CNC-milled unibody lid make ROG Zephyrus S portable enough for life on the go and tough enough to survive everyday abuse. In one fluid motion of hidden scissor-door hinges, it transforms from svelte sidekick to gaming powerhouse.
  • Shrinking bezels without sacrificing speed
    Super-narrow bezels draw you deeper into the action on the fast refresh rate display. The high refresh rate makes gameplay smoother and lowers input lag, while the short gray-to-gray response time produces sharper visuals with no blurring. With the full sRGB color gamut and wide viewing angles, ROG Zephyrus S blends speed and beauty without compromise.
  • Potent performance rivals desktops
    Don't be fooled by its lithe body; ROG Zephyrus S has ample power for AAA games, VR experiences, and serious creative work.
  • Cool under pressure
    The unique ROG Active Aerodynamic System (AAS) expands to help Zephyrus S sustain high GPU clocks with demanding games. Lifting the lid opens an intake that increases airflow compared to traditional designs. Anti-dust tunnels keep the four heatsinks clean to preserve cooling performance and system stability as the hours add up.
  • Aura Sync beyond the gaming keyboard
    The keyboard ensures precise input in the heat of battle, and it's built to last. You can customize the backlight colors and effects to suit your style, and another configurable RGB zone illuminates the AAS intake at the back. Aura Sync harmonizes lighting across compatible ROG mice, headsets, and other peripherals to give your setup a cohesive look.
  • Amp up your audio
    ROG Zephyrus S puts audio at the forefront with dual speakers aimed right at you. Smart amplifier tech keeps them within thermal and excursion limits, so you can pump up the volume without harming the cones. The resulting output is louder, with more bass and range that help you hear every sound, and you can plug in a headset for even more immersion.
  • Extensive connectivity
    ROG Zephyrus S has all the connectivity needed for gaming on the go. Type-C (USB-C) ports are available at USB 3.1 Gen 2 and Gen 1 speeds, while Type-A USB 3.1 Gen 2 and USB 2.0 ports are perfect for a gamepad and mouse. HDMI 2.0 at the back supports high refresh rate 4K UHD displays, so you can game and entertain on big-screen TVs.
ASUS ROG Zephyrus S GX531GW-ES008R - 15.6" - Core i7 8750H - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 10 Pro
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
16 GB DDR4 (1 x 8 GB + 8 GB (soldered))
Storage
512 GB SSD - NVMe
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD @ 144 Hz
Graphics
NVIDIA GeForce RTX 2070 / Intel UHD Graphics 630
Video Memory
8 GB GDDR6 SDRAM
VR Ready
Input Device
Mouse
Keyboard Backlight
Yes (RGB)
Integrated Webcam
802.11ac, Bluetooth 5.0
4-cell
36 cm x 26.8 cm x 1.61 cm
2.1 kg
SAR
0.02 W/kg (body), 0.02 W/kg (limb)
Notebook
Operating System
Windows 10 Pro
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Chipset
Mobile Intel HM370
Intel Turbo Boost Technology 2.0
RAM
16 GB (1 x 8 GB + 8 GB (soldered))
Max RAM Supported
24 GB
DDR4 SDRAM
Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
512 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
144 Hz
Widescreen
Image Aspect Ratio
16:9
Anti-glare, 72% NTSC colour gamut, 100% sRGB colour gamut, 178° horizontal and vertical viewing angle, 3 ms response rate, 75.35% Adobe RGB colour gamut
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
8 GB GDDR6 SDRAM
Video System Features
NVIDIA Optimus, NVIDIA G-SYNC, Max-Q design
VR Ready
Camera
Yes - 720p
Sound
Stereo speakers, array microphone
Input
Mouse, keyboard, touchpad
Keyboard Backlight
Yes (RGB)
4-zone illumination
Communications
Wireless
4-cell Lithium Ion
60 Wh
AC Adapter
Input
Output
230 Watt, 19.5 V, 11.8 A
Connections & Expansion
Headphone/microphone combo jack , HDMI , USB-C 3.1 Gen 1 , USB 3.1 Gen 2 , USB-C 3.1 Gen 2/DisplayPort , 2 x USB 2.0
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
SAR Value
2.1 kg
Optical Storage: None
Graphics: NVIDIA GeForce RTX 2070 / Intel UHD Graphics 630
Hard Drive Type: SSD
Type: Gaming Laptop
Brand: Asus
Price Range Ex VAT: 1500+
