Asus ROG Zephyrus G 15.6" Ryzen 7 3750H 16GB 512GB SSD GTX 1660TI
Quicklinx: FDDSWS00 Mfr#: GA502DU-AL025T
Display Size: 15.6in
Processor Model: 3750H
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
26 in stock
£999.00 ex VAT
£1,198.80 inc VAT
The ROG Zephyrus G deftly balances exceptional portability with potent performance to bring ultra-slim gaming laptop to a bigger audience. Its AMD Ryzen 7 processor and GeForce GTX 1660 Ti graphics power through work and play, while long-lasting battery keeps you running on the road. Immerse yourself in up to a 120Hz display framed by super-narrow bezels that practically melt away, and turn up the volume with smart amp technology that gets louder with less distortion.
  • Sleek and portable
    Streamlined design and stealthy styling help the ROG Zephyrus G blend in everywhere from battlestations and LAN parties to classrooms and coffee shops. Travel effortlessly between them with a compact body. It is perfect to carry in crowded bags and tight spaces.
  • Advanced performance
    Intelligently configured and expertly tuned, the ROG Zephyrus G starts with a powerful processor that slices through serious work and everyday multitasking.
  • Super-narrow bezels for superior immersion
    Movement and animation are much smoother, and wide viewing angles keep the picture from washing out when more people gather around for split-screen gaming, watching videos, and working on projects.
  • Smart Amplification technology
    The ROG Zephyrus G's twin front-firing speakers put you directly in the heat of the action. Powered by Smart Amp technology, the speakers stay within thermal and excursion limits no matter how much you crank up the volume. This mitigates distortion and prevents damage to the cones for audio that's louder, bassier, and has more dynamic range.
  • A stroke of gaming genius
    Gamers will feel right at home with the keyboard's desktop-inspired layout, which has separate function blocks for intuitive identification, plus dedicated hot keys that put volume, microphone mute. Overstroke technology triggers higher in each keystroke for faster responsiveness, and N-key rollover registers every press precisely in the heat of battle. Work or play into the night illuminated by the pristine glow of clean white backlighting.
  • Comprehensive connectivity
    Hook up your favorite devices and get in-game fast. The ROG Zephyrus G features one reversible Type-C port with peak interface bandwidth of 10Gbps via USB 3.1 Gen 2, plus three Type-A USB 3.1 Gen 1 ports that are perfect for your gamepad, mouse, and more. Use the HDMI 2.0 to play movies, videos, and games at up to 60Hz. Hop online with 802.11ac Wi-Fi or connect Gigabit Ethernet for a lower-latency connection that's perfect for fast-paced multiplayer games.
ASUS ROG Zephyrus G GA502DU-AL025T - 15.6" - Ryzen 7 3750H - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 10 Home 64-bit
AMD Ryzen 7 3750H / 2.3 GHz (4 GHz) / 6 MB Cache /
16 GB DDR4 (1 x 8 GB + 8 GB (soldered))
Storage
512 GB SSD NVMe
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce GTX 1660 Ti
Video Memory
6 GB GDDR6 SDRAM
Keyboard Backlight
Bluetooth, 802.11ac, Gigabit Ethernet
4-cell
36 cm x 25.2 cm x 2.04 cm
2.2 kg
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
RAM
16 GB (1 x 8 GB + 8 GB (soldered))
Max RAM Supported
24 GB
DDR4 SDRAM
Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
512 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare, 45% NTSC colour gamut, 120 Hz refresh rate, 62.5% sRGB colour gamut, 170° viewing angle, 47.1% Adobe RGB colour gamut
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
6 GB GDDR6 SDRAM
Video System Features
Max-Q design
Sound
Stereo speakers, array microphone
Audio Features
Input
Keyboard, touchpad
Keyboard Backlight
Chiclet keyboard
Communications
Wireless
Bluetooth, 802.11ac
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
76 Wh
AC Adapter
Input
Output
180 Watt, 20 V, 9 A
Connections & Expansion
Headphone/microphone combo jack , 3 x USB 3.1 Gen 1 , USB-C 3.1 Gen 2/DisplayPort 1.4 , LAN , HDMI
Case Material
Plastic, metal
System password
Power adapter
2.2 kg
Software applications
Asus ROG Zephyrus G 15.6 Bundle deal on Asus ROG Zephyrus G 15.6" Ryzen 7 3750H 16GB 512GB SSD GTX 1660TI
£1,098.17
Optical Storage: None
Graphics: NVIDIA GeForce GTX 1660 Ti
Hard Drive Type: SSD
Type: Gaming Laptop
Brand: Asus
Price Range Ex VAT: 750 - 1000
