What is ROG Whetstone?
Designed with input from pro-gaming team Taipei Assassins, ROG Whetstone features a Mayan-inspired textured surface and is the first ROG hybrid silicone-fabric mouse pad that gives you precise, ultra-smooth , quiet mouse tracking and control. ROG Whetstone incorporates the latest bonding and heat-sealing techniques to ensure a durable, high quality finish. Its special water-resistant coat is washable too - giving you a mouse pad that's ideal for a gaming setup at home, or at LAN parties. With ROG, we give you nothing but the best.
Mayan-inspired surface design gives you silent, swift and pixel-precise control, and super smooth glide. The surface works perfectly with both laser and optical sensors.
Rollable and highly portable hybrid design boasts exceptional durability, making it ideal for you to take to LAN parties.
Water-resistant coat for easy cleaning and long lifespan.
2mm thick ergonomic design enables you to game with comfort through the most intense battles unscathed.
Special 8-stage power bonding and heat-sealing techniques provide smooth, rounded fray-resistant edges and exceptional durability.
Non-slip silicone base grips firmly onto any surface. It doesn't slip, so you won't either.
Eco-friendly, premium quality for guaranteed victory
Prior to production, the materials that make up ROG Whetstone are subjected to the strictest material selection and manufacturing processes. ROG even received input from the world's finest professional gamers, and had them lab test hundreds of materials before deciding on the final design.
The resulting product is bluesign®-certified, and meets the world's most stringent safety and eco-friendly production requirements. ROG Whetstone is a premium, high quality product that's good for you, as well as the environment.
Whetstone story
A whetstone is a stone used for sharpening knives and other cutting tools. In the gaming world, deft, precise control often makes the difference between victory and defeat. Having a high performance gaming mouse isn't enough, ROG Whetstone is a gaming weapon that gives you the edge for ultimate performance.
Dimensions
320 x 270 x 2 mm
220 g
It gives you silent, swift and pixel-precise control, and super smooth glide. The surface works perfectly with both laser and optical sensors. -
Rollable and highly portable hybrid design boasts exceptional durability, making it ideal for you to take to LAN parties. -
Water-resistant coat is provided for easy cleaning and long lifespan. -
Thick ergonomic design
Thick ergonomic design enables you to game with comfort through the intense battles unscathed. -
Special 8-stage power bonding and heat-sealing techniques provide smooth, rounded fray-resistant edges and exceptional durability. -
- ASUS ROG Whetstone - mouse pad
- Product Type
- Mouse pad
- Product Material
- Fabric, silicone
- 32 cm x 27 cm
- 220 g
- Black
- Designed For
- ASUSPRO P1; ROG Zephyrus G14; S17; TUF Gaming A17; F15; FX505DT; VivoBook 14; 15; 17; VivoBook Flip 12 TP202NA; 14 TP401MA; X543UA; ZenBook 13; 14
- Product Type
- Mouse pad
- Product Material
- Fabric, silicone
- 32 cm
- 27 cm
- Thickness
- 0.2 cm
- 220 g
- Black
- Water-resistant, washable, non-slip, Mayan-inspired markings, laser-cut ROG logo
- Designed For
- ASUSPRO P1 P1440FA-C53P , ASUS ROG Zephyrus G14 GA401II-HE092T, GA401II-HE109T, GA401IU-HE002 , ASUS ROG Zephyrus S17 GX701LWS-EV029T, GX701LWS-EV076T, GX701LWS-HG052R, GX701LXS-HG007T , ASUS TUF Gaming A17 FX706II-AU031T , ASUS TUF Gaming F15 FX506LH-BQ030 , ASUS TUF Gaming FX505DT BQ137T, HN549T , ASUS VivoBook 14 K413FA-EK695T, M413IA-EB371T , ASUS VivoBook 15 F512JA-EJ011T, X512DA-EJ1458T, X512FB-BR468T, X512FJ-EJ529T, X512JA-BQ147T , ASUS VivoBook 17 M712DA-AU311T, X712FA-AU606R, X712FA-AU642T, X712FA-AU643T, X712FA-AU848T , ASUS VivoBook Flip 12 TP202NA CMSP, QMSP, XS04 , ASUS VivoBook Flip 14 TP401MA CMSP, QMSP , ASUS X543UA GO3047T, GQ2636T , ASUS ZenBook 13 UX334FAC-A4113T , ASUS ZenBook 14 UM433IQ-PURE5, UX425JA-BM090R, UX431FA-AN168T, UX433FAC-AI258R, UX434FAC-A5188T
