Asus ROG SWIFT PG278QR 27'' WQHD (2560 x 1440) Gaming monitor
CLEARANCE!
Clearance
Quicklinx: CZ0BWS00 Mfr#: PG278QR
ROG Swift PG248Q is a competition-grade gaming monitor that gives you seamless visuals and super-smooth gameplay. It features a 24-inch Full HD (1920 x 1080) panel with a 16:9 aspect ratio. It's NVIDIA G-SYNCTM-ready too. ROG Swift PG248Q boasts an overclockable 180Hz refresh rate and 1ms gray-to-gray (GTG) response time to eliminate screen tearing and choppy frame rates.
  • Incredible 180Hz refresh rate
    With an astonishing overclockable 180Hz (native 144Hz) refresh rate, fast-moving visuals pose no problem for ROG Swift PG248Q. There's no frustrating lag or motion blur, so you get the upper hand in first-person shooters, racing, real-time strategy and sports titles. You'll enjoy silky-smooth gameplay even at the highest visual settings, allowing you to react instantly to what's happening onscreen so you'll get that first strike in.
  • Lightning-fast 1ms rapid response time
    The ROG Swift PG248Q is the fastest in its class, boasting a 1ms response time to eliminate smearing and motion blur. This lets you react instantly to what you see onscreen, especially in fast paced games - allowing you to take corners like a pro racing car driver, or get that headshot like a battle-hardened sniper.
  • Gain a competitive edge with NVIDIA G-SYNC technology
    The ROG Swift PG248Q incorporates NVIDIA G-SYNC display technology to deliver the smoothest, fastest, and most breathtaking gaming imaginable. G-SYNC synchronizes the monitor's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. ROG Swift PG248Q lets you enjoy seamlessly-smooth and lag-free gameplay when playing the latest fast-paced first-person shooters, sports, and action-adventure titles.
ASUS ROG SWIFT PG278QR - 3D LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
3D Capable
Adaptive-Sync Technology
NVIDIA G-SYNC, NVIDIA G-Sync Compatible
5-way joystick, USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 165 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
62 cm x 23.8 cm x 43.3 cm
7 kg
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, E-Standby, ERP, CEL level 1, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class C
64 kWh
44 W
Diagonal Size
27"
3D Capable
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
24 - 165 Hz
Horizontal Refresh Rate
30 - 240 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
HDCP, Trace Free Technology, Light-in-Motion LED, 72% NTSC colour gamut, ASUS GamePlus, super narrow frame, Low Blue Light Mode, Flicker Free technology, nVidia 3D Vision, NVIDIA Ultra Low Motion Blur Technology, ASUS Smart Air Vent Design, ASUS GameVisual Technology, Colour Temperature Selection
62 cm x 23.8 cm x 43.3 cm - with stand
7 kg
Input
5-way joystick
DisplayPort , 2 x USB 3.0 downstream (Type A) , HDMI , Headphones , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
90 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 62 cm - depth: 6.6 cm - height: 36.6 cm , With stand - width: 62 cm - depth: 23.8 cm - height: 43.3 cm - weight: 7 kg
Shipping Width
75.6 cm
Shipping Depth
30 cm
Shipping Height
45.6 cm
Shipping Weight
10.6 kg
