Asus ROG Swift PG258Q 24.5 1920x1080 Gaming Monitor 1ms DP HDMI
Quicklinx: CXNTWS00 Mfr#: PG258Q
Diagonal Size: 24.5in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, HDMI
28 in stock
£494.52 ex VAT
£593.42 inc VAT
ROG Swift PG258Q is all about speed - making it the perfect monitor for eSports and fast-paced action games. This Full HD monitor is incredibly fast, with a 240 Hz native refresh rate, 1 ms response time and NVIDIA G-SYNC technology for silky-smooth gameplay and ultra-realistic visuals. On top of that, Swift PG258Q has distinct ROG-inspired design elements that let everyone know that this is no ordinary gaming monitor.
ASUS ROG SWIFT PG258Q - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Class
Class B
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
27 W
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 240 Hz, HDMI: 60 Hz)
Pixel Pitch
0.2832 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Dark grey, plasma cooper
56.41 cm x 25.37 cm x 38.37 cm
5.6 kg
UL, TUV, VCCI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, E-Standby, ERP, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification, DisplayPort 1.2
Display Type
Energy Class
Class B
40 kWh
27 W
Diagonal Size
24.5"
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2832 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
30 - 240 Hz
Horizontal Refresh Rate
67 - 255 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, frameless, Trace Free Technology, nVidia 3D Vision 2 Ready, NVIDIA 3D LightBoost technology, 5-way Navigation Key, integrated cable management, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, NVIDIA G-SYNC compatible, NVIDIA Ultra Low Motion Blur Technology, ASUS Smart Air Vent Design, ASUS GameVisual Technology, Colour Temperature Selection
56.41 cm x 25.37 cm x 38.37 cm - with stand
5.6 kg
DisplayPort , 2 x USB 3.0 downstream (Type A) , HDMI , Headphones , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
100
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
65 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 56.41 cm - depth: 25.37 cm - height: 38.37 cm - weight: 5.6 kg , Without stand - width: 56.16 cm - depth: 7.25 cm - height: 33.06 cm - weight: 3.14 kg
Shipping Width
66.14 cm
Shipping Depth
23.9 cm
Shipping Height
44.3 cm
Shipping Weight
7.9 kg
Asus ROG Swift PG258Q 24.5 1920x1080 Gaming Monitor 1ms DP HDMI Bundle deal on Asus ROG Swift PG258Q 24.5 1920x1080 Gaming Monitor 1ms DP HDMI
£593.69
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Brand: Asus
Price Range Ex VAT: 300 - 500
