Asus ROG Swift PG248Q 3D LED 24" Full HD Gaming Monitor
Clearance!
Clearance
Quicklinx: D0ZFWS00 Mfr#: PG248Q
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Interfaces: DisplayPort, HDMI
10 in stock
£400.27 ex VAT
£480.32 inc VAT
ROG Swift PG248Q is a competition-grade gaming monitor that gives you seamless visuals and super-smooth gameplay. It features a 24-inch Full HD (1920 x 1080) panel with a 16:9 aspect ratio. It's NVIDIA G-SYNC-ready too. ROG Swift PG248Q boasts an overclockable 180Hz refresh rate and 1ms gray-to-gray (GTG) response time to eliminate screen tearing and choppy frame rates.
With an astonishing overclockable 180Hz (native 144Hz) refresh rate, fast-moving visuals pose no problem for ROG Swift PG248Q. There's no frustrating lag or motion blur, so you get the upper hand in first-person shooters, racing, real-time strategy and sports titles. You'll enjoy silky-smooth gameplay even at the highest visual settings, allowing you to react instantly to what's happening onscreen so you'll get that first strike in.
ROG Swift PG248Q is the fastest in its class, boasting a 1ms response time to eliminate smearing and motion blur. This lets you react instantly to what you see onscreen, especially in fast paced games - allowing you to take corners like a pro racing car driver, or get that headshot like a battle-hardened sniper.
ROG Swift PG248Q incorporates NVIDIA G-SYNC display technology to deliver the smoothest, fastest, and most breathtaking gaming imaginable. G-SYNC synchronizes the monitor's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. ROG Swift PG248Q lets you enjoy seamlessly-smooth and lag-free gameplay when playing the latest fast-paced first-person shooters, sports, and action-adventure titles.
ROG Swift PG248Q is compatible with the NVIDIA 3D Vision 2 kit to open up a world of 3D gaming. All you need is a NVIDIA GeForce graphics card and 3D glasses for a more immersive gaming and movie-watching experience. And with the latest NVIDIA 3D LightBoost Technology, you'll enjoy brighter 3D visuals, without an increase in energy consumption.
ROG Swift PG248Q's slim profile and super-narrow bezel makes it perfect for almost seamless multi-display setups so your eyes move swiftly from one monitor to another. It can also be VESA wall-mounted - an even easier way to have a multi-display gaming setup.
  • Exclusive monitor
  • Incredible 180Hz refresh rate
  • Lightning-fast 1ms rapid response time
    The ROG Swift PG248Q is the fastest in its class, boasting a 1ms response time to eliminate smearing and motion blur. This lets you react instantly to what you see onscreen, especially in fast paced games - allowing you to take corners like a pro racing car driver, or get that headshot like a battle-hardened sniper.
  • Gain a competitive edge with NVIDIA G-SYNC Technology
    The ROG Swift PG248Q incorporates NVIDIA G-SYNC display technology to deliver the smoothest, fastest, and most breathtaking gaming imaginable. G-SYNC synchronizes the monitor's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. ROG Swift PG248Q lets you enjoy seamlessly-smooth and lag-free gameplay when playing the latest fast-paced first-person shooters, sports, and action-adventure titles.
  • ASUS-exclusive GamePlus technology
    The ASUS GamePlus hotkey gives you in-game enhancements so you get more out of your game.
  • ASUS-exclusive GameVisual technology
    ASUS GameVisual Technology has six pre-set display modes to optimize visuals for different types of content. This unique feature can be easily accessed through a hotkey or the On Screen Display (OSD) settings menu.
  • NVIDIA 3D Vision-ready
  • Super-narrow bezel design for seamless multi-display setups
    The ROG Swift PG248Q's slim profile and super-narrow bezel makes it perfect for almost seamless multi-display setups so your eyes move swiftly from one monitor to another. It can also be VESA wall-mounted - an even easier way to have a multi-display gaming setup.
  • Robust connectivity with exclusive gaming hotkeys
    ROG Swift PG248Q gives you flexible connectivity options for Full HD (1920 x 1080) input via its DisplayPort1.2 and HDMI ports. It also has two USB 3.0 ports for your mouse and keyboard, and can charge your mobile devices while gaming.
  • Ultra-low blue light technology
    The ROG Swift PG248Q also comes with the ASUS Ultra Low Blue Light filters to protect you from harmful blue light. You can easily access and select four different filter settings onscreen through a handy five-way joystick makes it easy to jump through the On-screen display (OSD) menus to fulfill your different scenarios.
  • Low blue light level
    The ROG Swift PG248Q gaming monitor has undergone stringent performance tests and is certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, to be flicker-free and to emit low blue light levels.
  • Flicker free technology
    Flicker-Free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other damaging effects when you're embroiled in long, drawn-out gaming sessions.
  • Ergonomic tilt, swivel, pivot, and height adjustable stand
    The ROG Swift PG248Q is specially designed for marathon gaming sessions. It has an ergonomically-designed stand with tilt, swivel, pivot, and height adjustment so you can always find that ideal viewing position whether you're on the couch or sitting on your bed.
  • Keeping it cool with a smart air vent design
    The ROG Swift PG248Q employs a custom heatsink that's double the size to make sure the monitor stays cool during marathon gaming sessions. Cooling is also aided by a Smart Air Venting Design that uses convective currents to generate airflow. This passive setup works entirely without fans, making it completely silent and maintenance-free.
  • Awesome LED Light-in-Motion Effects
    The ROG Swift PG248Q Gaming Monitor comes with a mysterious and intricately-patterned base that can illuminate with an LED Light-in-Motion feature.
ASUS ROG SWIFT PG248Q - 3D LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
3D Capable
Adaptive-Sync Technology
NVIDIA G-SYNC
5-way joystick, USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 180 Hz
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
56.16 cm x 23.79 cm x 41.82 cm
6.6 kg
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, E-Standby, ERP, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class B
44 kWh
30 W
Diagonal Size
24"
3D Capable
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
30 - 180 Hz
Horizontal Refresh Rate
67 - 212 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Trace Free Technology, Light-in-Motion LED, NVIDIA 3D LightBoost technology, ASUS GamePlus, super narrow frame, Flicker Free technology, NVIDIA G-SYNC compatible, nVidia 3D Vision, NVIDIA Ultra Low Motion Blur Technology, ASUS Smart Air Vent Design, ASUS GameVisual Technology, Colour Temperature Selection
56.16 cm x 23.79 cm x 41.82 cm - with stand
6.6 kg
Input
5-way joystick
DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , HDMI , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
65 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Microsoft Windows 7 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 56.16 cm - depth: 7 cm - height: 32.97 cm , With stand - width: 56.16 cm - depth: 23.79 cm - height: 41.82 cm - weight: 6.6 kg
Shipping Width
73.5 cm
Shipping Depth
28 cm
Shipping Height
41.5 cm
Shipping Weight
9.5 kg
Asus ROG Swift PG248Q 3D LED 24 Bundle deal on Asus ROG Swift PG248Q 3D LED 24" Full HD Gaming Monitor
£499.44
Diagonal Size: 24in
Response Time: 1ms
Interfaces: HDMI
Brand: Asus
Price Range Ex VAT: 300 - 500
