The Swift PG348Q expands your scope, allowing faster target acquisition while increasing immersive visuals with a 34-inch curved ultra-wide IPS panel. Bristling with advanced display tech, the Swift PG348Q also features NVIDIA G-SYNC technology for smooth and seamless gameplay, while simultaneously sporting a great refresh rate, eliminating roadblocks between your skill and victory. Add the armored design and amazing ASUS features and you're looking at a monitor that is truly unrivaled.
Amazing design
It features an incredible design with a great color scheme, and has built-in ROG light effects on its stand to add ambience to your gaming setup. -
Stunning visuals
The ROG Swift PG348Q gaming monitor features a 34-inch ultra-wide panel with high pixel density so you enjoy greater details when playing games or watching movies. Its ultra-wide 21:9 aspect panel gives you more onscreen desktop space, so there's even more room for your various application windows when it's time to get work done. ROG Swift PG348Q takes realism up a notch, giving you visuals with great textures, so even your in-game terrain maps boast impressive levels of detail. -
Panoramic gaming arena
The panel curvature of ROG Swift PG348Q ensures every point on the curved display is equidistant to your eyes, so you get a comfortable viewing experience even during marathon gaming sessions. On top of that, the curved display makes movies and games more immersive than ever! -
Seamless gameplay
ROG Swift PG348Q has a high refresh rate to decimate lag and motion blur so that you have the upper hand in first person shooters, racer, real-time strategy, and sports titles. This fast refresh rate lets you play games at the highest visual settings and lets you react instantly to what's onscreen - so you'll always get that first strike in. -
NVIDIA G-SYNC display technology delivers the smooth, fast, and breathtaking gaming by eliminating screen tearing, and minimizing display stutter and input lag. ROG Swift PG348Q gives you smooth and seamless lag-free visuals when playing the fast-paced first-person shooters, sports, and action-adventure titles. -
GamePlus technology
ASUS GamePlus technology is ready to help you attain victory. Simply press the hotkey and select from the following enhancements. You can choose between persistent crosshairs and fine tune their position, ensuring pinpoint accuracy in first-person shooters. Enjoy perfect aim even when the game doesn't provide its own crosshair or sights. -
Frameless edge-to-edge design
Designed for those who want the amazing battle station, the PG348Q features frameless design, nearly seamless for multi-display setups, for an even greater degree of immersion. -
Robust connectivity
ROG Swift PG348Q has a wide selection of connectivity opportunities including DisplayPort and HDMI. There are also four USB 3.0 ports for your mouse and keyboard, they can even charge your mobile devices while gaming. -
Flicker-Free technology
ROG Swift PG348Q reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other damaging effects when you're embroiled in long, drawn-out gaming sessions. -
Ergonomic design
ROG Swift PG348Q is specially designed for marathon gaming sessions. It has an ergonomically designed stand with swivel, tilt, and height adjustment so you can always find the ideal viewing position.
- ASUS ROG SWIFT PG348Q - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class B
- Energy Consumption per Year
- 77 kWh
- Power Consumption (On mode)
- 53 W
- Curved Screen
- Adaptive-Sync Technology
- NVIDIA G-SYNC
- 5-way joystick, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440 at 100 Hz
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.074 billion colours (10-bit)
- Input Connectors
- HDMI, DisplayPort
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Armor titanium, plasma cooper
- 82.9 cm x 29.7 cm x 55.8 cm
- 11.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, RCM, CEL level 2, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
- Display Type
- Energy Class
- Class B
- 77 kWh
- 53 W
- Diagonal Size
- 34"
- Curved Screen
- Yes (3800R)
- NVIDIA G-SYNC
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.2325 mm
- Pixel Per Inch
- 109
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 24 - 100 Hz
- Horizontal Refresh Rate
- 30 - 140 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Colour temperature
- HDCP, frameless, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, 100% sRGB colour gamut, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS Smart Air Vent Design, ASUS GameVisual Technology, Turbo key, Colour Temperature Selection
- 82.9 cm x 29.7 cm x 55.8 cm - with stand
- 11.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
Input
- 5-way joystick
- DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , HDMI , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 100
- Height Adjustment
- 115 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 100 Watt
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 82.9 cm - depth: 10.9 cm - height: 37.3 cm , With stand - width: 82.9 cm - depth: 29.7 cm - height: 55.8 cm - weight: 11.2 kg
- Shipping Width
- 32 cm
- Shipping Depth
- 94.2 cm
- Shipping Height
- 50.8 cm
- Shipping Weight
- 15.5 kg
- ENERGY STAR Certified
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£996.16
