Asus ROG SWIFT Curved PG348Q 34" UWQHD (3440x1440) Gaming monitor
Quicklinx: CZ09WS00 Mfr#: PG348Q
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£866.67 ex VAT
£1,040.00 inc VAT
The Swift PG348Q expands your scope, allowing faster target acquisition while increasing immersive visuals with a 34-inch curved ultra-wide IPS panel. Bristling with advanced display tech, the Swift PG348Q also features NVIDIA G-SYNC technology for smooth and seamless gameplay, while simultaneously sporting a great refresh rate, eliminating roadblocks between your skill and victory. Add the armored design and amazing ASUS features and you're looking at a monitor that is truly unrivaled.
  • Amazing design
    It features an incredible design with a great color scheme, and has built-in ROG light effects on its stand to add ambience to your gaming setup.
  • Stunning visuals
    The ROG Swift PG348Q gaming monitor features a 34-inch ultra-wide panel with high pixel density so you enjoy greater details when playing games or watching movies. Its ultra-wide 21:9 aspect panel gives you more onscreen desktop space, so there's even more room for your various application windows when it's time to get work done. ROG Swift PG348Q takes realism up a notch, giving you visuals with great textures, so even your in-game terrain maps boast impressive levels of detail.
  • Panoramic gaming arena
    The panel curvature of ROG Swift PG348Q ensures every point on the curved display is equidistant to your eyes, so you get a comfortable viewing experience even during marathon gaming sessions. On top of that, the curved display makes movies and games more immersive than ever!
  • Seamless gameplay
    ROG Swift PG348Q has a high refresh rate to decimate lag and motion blur so that you have the upper hand in first person shooters, racer, real-time strategy, and sports titles. This fast refresh rate lets you play games at the highest visual settings and lets you react instantly to what's onscreen - so you'll always get that first strike in.
  • NVIDIA G-SYNC technology
    NVIDIA G-SYNC display technology delivers the smooth, fast, and breathtaking gaming by eliminating screen tearing, and minimizing display stutter and input lag. ROG Swift PG348Q gives you smooth and seamless lag-free visuals when playing the fast-paced first-person shooters, sports, and action-adventure titles.
  • GamePlus technology
    ASUS GamePlus technology is ready to help you attain victory. Simply press the hotkey and select from the following enhancements. You can choose between persistent crosshairs and fine tune their position, ensuring pinpoint accuracy in first-person shooters. Enjoy perfect aim even when the game doesn't provide its own crosshair or sights.
  • Frameless edge-to-edge design
    Designed for those who want the amazing battle station, the PG348Q features frameless design, nearly seamless for multi-display setups, for an even greater degree of immersion.
  • Robust connectivity
    ROG Swift PG348Q has a wide selection of connectivity opportunities including DisplayPort and HDMI. There are also four USB 3.0 ports for your mouse and keyboard, they can even charge your mobile devices while gaming.
  • Flicker-Free technology
    ROG Swift PG348Q reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other damaging effects when you're embroiled in long, drawn-out gaming sessions.
  • Ergonomic design
    ROG Swift PG348Q is specially designed for marathon gaming sessions. It has an ergonomically designed stand with swivel, tilt, and height adjustment so you can always find the ideal viewing position.
ASUS ROG SWIFT PG348Q - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
77 kWh
Power Consumption (On mode)
53 W
Curved Screen
Adaptive-Sync Technology
NVIDIA G-SYNC
5-way joystick, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 100 Hz
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Armor titanium, plasma cooper
82.9 cm x 29.7 cm x 55.8 cm
11.2 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, RCM, CEL level 2, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class B
77 kWh
53 W
Diagonal Size
34"
Curved Screen
Yes (3800R)
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2325 mm
Pixel Per Inch
109
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
24 - 100 Hz
Horizontal Refresh Rate
30 - 140 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Colour temperature
HDCP, frameless, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, 100% sRGB colour gamut, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS Smart Air Vent Design, ASUS GameVisual Technology, Turbo key, Colour Temperature Selection
82.9 cm x 29.7 cm x 55.8 cm - with stand
11.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
5-way joystick
DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , HDMI , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
100
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
100 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 82.9 cm - depth: 10.9 cm - height: 37.3 cm , With stand - width: 82.9 cm - depth: 29.7 cm - height: 55.8 cm - weight: 11.2 kg
Shipping Width
32 cm
Shipping Depth
94.2 cm
Shipping Height
50.8 cm
Shipping Weight
15.5 kg
ENERGY STAR Certified
Asus ROG SWIFT Curved PG348Q 34 Bundle deal on Asus ROG SWIFT Curved PG348Q 34" UWQHD (3440x1440) Gaming monitor
£965.84
Diagonal Size: 34in
Response Time: 5ms
Interfaces: HDMI
Brand: Asus
Price Range Ex VAT: 750 - 1000
