Your basket is empty
Asus ROG STRIX X99 GAMING Intel X99 S2011-V3 DDR4 M.2 U.2 ATX
Quicklinx: C3JPWS00 Mfr#: STRIX X99 GAMING
Processor Socket: LGA2011-v3 Socket
Chipset: Intel X99 Express
Graphics: None
Form Factor: ATX
Memory Support: DDR4 SDRAM
  • IEEE 802.11n
£215.22 ex VAT
£258.26 inc VAT
The Gamer's Edge for X99
  • Intel® Core™ i7 processors on LGA 2011-v3 socket
  • Quad-channel DDR4 3333 (OC) support
  • OC Socket, 5-Way Optimization and second-generation T-Topology: Easy and stable overclocking
  • Aura RGB illumination, Aura 4-pin RGB-strip header and customizable color decals: True gaming aesthetics
  • SupremeFX and Sonic Radar II: Flawless audio with stealthy, game-dominating overlay
  • Top-speed protected networking: Intel Gigabit Ethernet, LANGuard and GameFirst technology
  • Gamer's Guardian: SafeSlot and smart DIY features
  • Ultra-speedy transfers for faster gaming: 2x2 802.11ac MU-MIMO Wi-Fi, U.2 and M.2, USB 3.1 Type A+C, RAMCache
Strix is the newest recruit into the Republic of Gamers(ROG) — and ROG Strix X99 Gaming is the first ROG Strix motherboard. ROG Strix X99 delivers premier performance, innovation, and confident dynamism to release your inner rebel. The bold design and bright colors channel your spirit of fierce individualism, charging every gaming experience with thrilling energy. Want to dominate with epic speed and agility? Join the Republic with ROG Strix X99 Gaming!
AURA LIGHTING CONTROL
Customize your own favorite LED effects with Aura, the intuitive lighting-control software, to cast a stunning multi-color glow across your build via the motherboard's powerful built-in RGB LEDs or attached RGB strips via the onboard 4-pin header, or both — and in perfect synchronization! Fire up Aura and then enjoy the creative freedom of 10 different lighting schemes. You're even able to sync your lighting style with the ever-growing portfolio of Aura-capable gear, and mix and match your Aura effects with the included color decals!
AURA 4-PIN RGB-STRIP
Forget the faff of external RGB controllers! With Aura RGB Strip header, it's quick and easy to cast brilliant colors across your rig and room: Just slide standard 12V RGB strips onto the 4-pin Aura RGB-strip headers, then weave your lighting any way you like.
SUPREMEFX - SHIELDED AUDIO, SUPERIOR SOUND
SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable 115dB signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected 5V power supply. Supreme FX's superior components, including the trusted Realtek ALC1150 codec, maximize acoustic performance and eliminate interference – so you hear only the very best from your gaming headset or speakers!
ASUS ROG STRIX X99 GAMING - motherboard - ATX - LGA2011-v3 Socket - X99
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7 Extreme Edition, Core i7
Max RAM Size
128 GB
RAM Supported
8 DIMM slots - DDR4
Storage Ports
4 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2, 1 x U.2 port
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
128 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3333 MHz (O.C.)
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
SupremeFX
High Definition Audio
LAN
Network Controller
Intel I218V
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x8, x8 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 4 x 7pin SATA, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 1 x M.2, 1 x U.2 , SATA-600 -connectors: 4 x 7pin Serial ATA
RAID Features
Intel Smart Response Technology
1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x USB 3.1 , 1 x USB-C
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, MemOK!, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, ASUS DIGI+ VRM, Intel Smart Response Technology, USB 3.0 Boost, Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, Dual Intelligent Processors 5, LANGuard, Sonic Radar II, Intel Rapid Recovery Technology, ASUS OC Socket, USB 3.1 Boost, GameFirst IV, ASUS Gamer's Guardian, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS SafeSlot, Intel Turbo Boost Technology 3.0
Cable ties, I/O back plate, ROG cable lables, ASUS 2T2R Wi-Fi moving aerials, 1 x M.2 screw, ROG fan stickers, customisable colour decals
4 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger+, ASUS AI Suite III, ASUS Turbo App, Mobo Connect, PC Cleaner, ASUS RAMCache, Overwolf, ASUS EZ Flash 3, ROG GameFirst IV
30.5 cm
24.4 cm
Asus ROG STRIX X99 GAMING Intel X99 S2011-V3 DDR4 M.2 U.2 ATX Bundle deal on Asus ROG STRIX X99 GAMING Intel X99 S2011-V3 DDR4 M.2 U.2 ATX
£228.71
saving £7.22
Graphics: None
Form Factor: ATX
Brand: Asus
Price Range Ex VAT: 150 - 300
