ROG STRIX X99 GAMING
The Gamer's Edge for X99
- Intel® Core™ i7 processors on LGA 2011-v3 socket
- Quad-channel DDR4 3333 (OC) support
- OC Socket, 5-Way Optimization and second-generation T-Topology: Easy and stable overclocking
- Aura RGB illumination, Aura 4-pin RGB-strip header and customizable color decals: True gaming aesthetics
- SupremeFX and Sonic Radar II: Flawless audio with stealthy, game-dominating overlay
- Top-speed protected networking: Intel Gigabit Ethernet, LANGuard and GameFirst technology
- Gamer's Guardian: SafeSlot and smart DIY features
- Ultra-speedy transfers for faster gaming: 2x2 802.11ac MU-MIMO Wi-Fi, U.2 and M.2, USB 3.1 Type A+C, RAMCache
Strix is the newest recruit into the Republic of Gamers(ROG) — and ROG Strix X99 Gaming is the first ROG Strix motherboard. ROG Strix X99 delivers premier performance, innovation, and confident dynamism to release your inner rebel. The bold design and bright colors channel your spirit of fierce individualism, charging every gaming experience with thrilling energy. Want to dominate with epic speed and agility? Join the Republic with ROG Strix X99 Gaming!
AURA LIGHTING CONTROL
Customize your own favorite LED effects with Aura, the intuitive lighting-control software, to cast a stunning multi-color glow across your build via the motherboard's powerful built-in RGB LEDs or attached RGB strips via the onboard 4-pin header, or both — and in perfect synchronization! Fire up Aura and then enjoy the creative freedom of 10 different lighting schemes. You're even able to sync your lighting style with the ever-growing portfolio of Aura-capable gear, and mix and match your Aura effects with the included color decals!
AURA 4-PIN RGB-STRIP
Forget the faff of external RGB controllers! With Aura RGB Strip header, it's quick and easy to cast brilliant colors across your rig and room: Just slide standard 12V RGB strips onto the 4-pin Aura RGB-strip headers, then weave your lighting any way you like.
SUPREMEFX - SHIELDED AUDIO, SUPERIOR SOUND
SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable 115dB signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected 5V power supply. Supreme FX's superior components, including the trusted Realtek ALC1150 codec, maximize acoustic performance and eliminate interference – so you hear only the very best from your gaming headset or speakers!
Forget the faff of external RGB controllers! With Aura RGB-strip header, it's quick and easy to cast beautiful colors across your rig and room. Just slide standard 12 V RGB strips onto the 4-pin Aura RGB-strip headers, then weave your lighting any way you like. -
Shielded audio, amazing sound
Supreme FX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable 115 dB signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected 5 V power supply. Supreme FX's superior components, including the trusted Realtek ALC1150 codec, maximize acoustic performance and eliminate interference - so you hear only the very best from your gaming headset or speakers! -
Scan and detect to dominate
Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill, plus Audio Enhancement technology clarifies every last sound - so you hear the distant sound of enemy footsteps and become the hunter, not the hunted! -
More throughput, less CPU usage and great gaming experiences
ROG Strix X99 Gaming features the very latest Intel Ethernet (I218-V) for faster, smoother gaming - always. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay. -
Pumped-up throughput
LANGuard means safer, more reliable connections for your battles! Enhanced signal-coupling technology and surface-mounting processes join forces to protect your ROG Strix X99 Gaming's connection and deliver pumped-up throughput, plus electrostatically-guarded and surge-protected components (ESD Guards) for 1.9X-greater tolerance to static electricity and 2.5X-greater protection (up to 15KV) against surges! -
Drive CPU and DDR4 performance beyond all expectations
Designed to break performance barriers, ASUS OC Socket utilizes extra pins to connect a proprietary circuit to contacts found on land grid array (LGA). Combined with a customized UEFI, this feature enables higher DDR4 memory frequencies, lower latencies and enhanced stability while overclocking, extending all the way to extreme overclocking conditions, such as liquid nitrogen (LN2). -
Cache bus voltage adjustment
The cache bus links areas such as CPU cores, DDR4 memory controllers, system agent and the shared L3 cache - so it's a critical interconnect for the whole CPU subsystem. A higher cache-bus frequency directly accelerates subsystem performance, so ASUS OC Socket exclusively provides an adjustable cache-bus voltage to reach higher cache bus frequencies. -
Speed your game loads
Intelligent technology that effectively caches an entire storage device so that favorite games and apps launch at breakneck speeds, getting to work the moment it's activated. RAMCache turns milliseconds into microseconds to boost game-load times to stratospheric levels!
- ASUS ROG STRIX X99 GAMING - motherboard - ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition, Core i7
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4
- Storage Ports
- 4 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2, 1 x U.2 port
- USB / FireWire Ports
- USB 3.0, USB 3.1, USB-C 1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3333 MHz (O.C.)
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
- Audio Codec
- SupremeFX
- High Definition Audio
LAN
- Network Controller
- Intel I218V
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x8, x8 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin SATA, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 1 x M.2, 1 x U.2 , SATA-600 -connectors: 4 x 7pin Serial ATA
- RAID Features
- Intel Smart Response Technology
- 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x USB 3.1 , 1 x USB-C
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x serial - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, MemOK!, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, ASUS DIGI+ VRM, Intel Smart Response Technology, USB 3.0 Boost, Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, Dual Intelligent Processors 5, LANGuard, Sonic Radar II, Intel Rapid Recovery Technology, ASUS OC Socket, USB 3.1 Boost, GameFirst IV, ASUS Gamer's Guardian, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS SafeSlot, Intel Turbo Boost Technology 3.0
- Included Accessories
- Cable ties, I/O back plate, ROG cable lables, ASUS 2T2R Wi-Fi moving aerials, 1 x M.2 screw, ROG fan stickers, customisable colour decals
- Cables Included
- 4 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger+, ASUS AI Suite III, ASUS Turbo App, Mobo Connect, PC Cleaner, ASUS RAMCache, Overwolf, ASUS EZ Flash 3, ROG GameFirst IV
- 30.5 cm
- 24.4 cm
