Asus ROG Strix SCAR III G731GV EV025T Core i7-9750H 16GB 1TB SSHD RTX2060
Quicklinx: FDDRWS00 Mfr#: G731GV-EV025T
Display Size: 17.3in
Processor Model: I7-9750H
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 1.512TB
  • Core i7
£1,641.93 ex VAT
£1,970.31 inc VAT
FIGHT TILL DAYLIGHT
Aim for esports excellence with the ROG Strix SCAR III, engineered to compete at the top tier of Windows 10 Pro gaming. Intelligent Cooling unleashes the raw power of the 9th Gen Intel Core CPU and GeForce RTX™ graphics, while the world’s fastest 240Hz/3ms laptop display lets you play at the speed of pro gaming. Jump into multiplayer matches anywhere with stronger RangeBoost Wi-Fi, show off your personality with the wraparound Aura Sync light bar, and gain privacy for personal data with the new ROG Keystone.
FORWARD-THINKING FUNCTIONAL DESIGN
Efficiency and innovation unite in the sleek, gunmetal grey ROG Strix SCAR III. Its strategic design is inspired by our collaboration with BMW Designworks Group, and carves out a cooling advantage with its 3D Flow Zone. The subtle, carbon-patterned interior is accented by Aura Sync lighting that extends across the new wraparound light bar, keyboard, and ROG logo. Whether you’re gearing up for competition or hopping into quickplay, this metal-capped machine is fine-tuned and ready for action.
INTRODUCING THE KEYSTONE
Keystones offer a versatile new way to personalize your machine and protect your personal data. These physical, NFC-enabled keys fit neatly into the Strix SCAR III’s chassis, adding a subtle accent along the trim. When docked, they instantly transform your machine with different effects and game-specific profiles, or unlock access to a secret Shadow Drive for covert private storage. This is only the beginning of the Keystone’s potential. Glimpse the future today.
SEE THE GAME AT PROFESSIONAL SPEED
Play at the speed of professional esports with the world’s fastest gaming laptop display. The 240Hz/3ms panel enables true high-FPS gameplay capable of keeping up with competitive gaming at the highest level. Stay in the flow of fast-paced action with impeccably smooth, crisp visuals that heighten your immersion. Get an edge in combat where rapid response and environmental awareness are crucial to victory. Experience games the way the pros do, and take your skills to the next level.
  • Specifications vary according to model.
ASUS ROG Strix SCAR III G731GV EV025T - 17.3" - Core i7 9750H - 16 GB RAM - 512 GB SSD + 1 TB Hybrid Drive
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i7 (9th Gen) 9750H / 2.6 GHz (4.5 GHz)
16 GB DDR4 (2 x 8 GB)
Storage
512 GB SSD NVMe + 1 TB Hybrid Drive / 5400 rpm
Optical Drive
No optical drive
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce RTX 2060 / Intel UHD Graphics 630
Video Memory
6 GB GDDR6 SDRAM
Keyboard Backlight
Yes (RGB)
802.11ac, Bluetooth 5.0, Gigabit Ethernet
4-cell
39.9 cm x 29.3 cm x 2.62 cm
2.85 kg
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4.5 GHz
Number of Cores
6-core
64-bit Computing
Chipset
Mobile Intel HM370
Intel Turbo Boost Technology
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
512 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Secondary Storage
1 TB Hybrid Drive SATA / 5400 rpm - Seagate
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Bezel Type
Raised
Anti-glare, 72% NTSC colour gamut, 100% sRGB colour gamut, 3 ms response rate, 144 Hz refresh rate, 75.35% Adobe RGB colour gamut, 170° viewing angle
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
6 GB GDDR6 SDRAM
Video System Features
NVIDIA Optimus
Sound
Stereo speakers, array microphone
Input
Keyboard, touchpad
Keyboard Backlight
Yes (RGB)
Chiclet keyboard, per-key RGB, keystone button
Communications
Wireless
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
66 Wh
AC Adapter
Input
Output
230 Watt, 19.5 V, 11.8 A
Connections & Expansion
Headphone/microphone combo jack , USB-C 3.1 Gen 2/DisplayPort 1.4 , 3 x USB 3.1 , HDMI , LAN
Case Material
Polycarbonate ABS, plastic
System password
1080P webcam, power adapter, palm rest label
2.85 kg
Software applications
Asus ROG Strix SCAR III G731GV EV025T Core i7-9750H 16GB 1TB SSHD RTX2060 Bundle deal on Asus ROG Strix SCAR III G731GV EV025T Core i7-9750H 16GB 1TB SSHD RTX2060
£1,741.10
Optical Storage: None
Graphics: NVIDIA GeForce RTX 2060 / Intel UHD Graphics 630
Hard Drive Type: SSD
Type: Gaming Laptop
Brand: Asus
Price Range Ex VAT: 1500+
