Asus ROG Strix SCAR II 15.6" Core i7-8750H 16GB 256GB SSD + 1TB RTX 2070
Quicklinx: FDDPWS00 Mfr#: GL504GW-ES012T
  • Core i7
  • IEEE 802.11n
To give you the maximum advantage in combat, Strix SCAR II features a narrow-bezel display with a fast response time - a must-have for hardcore gamers and e-sports players.
  • Ultra-responsive, narrow-bezel display
    To give you the maximum advantage in combat, Strix SCAR II features a super-narrow-bezel display with a fast response time - a must-have for hardcore gamers and e-sports players. The modern design also results in a less distracting frame, allowing for a more compact body that's narrower and lighter.
  • Set your sights on an upgrade
    Strix SCAR II features an IPS-level display with a superior refresh rate and a fast response time for super-smooth visuals with little or no motion blur. The panel ensures brighter visuals.
  • Stay cool under fire
    The HyperCool Pro thermal system has a host of features to help Strix SCAR II get more out of its GPU and CPU. There's an extended cooling plate to spread heat evenly, and two high-performance fans, that deliver stronger airflow and increase air pressure to ensure a stable system even under heavy loads.
  • Aura Sync for ultimate personalization
    Aura Sync technology gives your entire gaming setup a consistent look and feel. Match the colors of the ROG logo, keyboard and light bar on Strix SCAR II with Aura Sync-supported gaming mice, headsets, and other peripherals.
ASUS ROG Strix SCAR II GL504GW ES012T - 15.6" - Intel Core i7 8750H - 16 GB RAM - 256 GB SSD + 1 TB Hybrid Drive
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz)
16 GB DDR4 (2 x 8 GB)
Storage
256 GB SSD - NVMe + 1 TB Hybrid Drive / 5400 rpm
Display
15.6" LED backlight 1920 x 1080 / Full HD @ 144 Hz
Graphics
NVIDIA GeForce RTX 2070 / Intel UHD Graphics 630
Video Memory
8 GB GDDR6 SDRAM
Gaming
Keyboard Backlight
Yes (RGB)
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
4-cell
Black, gun metal
36.1 cm x 26.2 cm x 2.61 cm
2.4 kg
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
64-bit Computing
Chipset
Mobile Intel HM370
Intel Turbo Boost Technology 2.0
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Secondary Storage
1 TB Hybrid Drive SATA / 5400 rpm - Seagate
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
144 Hz
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
100% sRGB, 72% NTSC, 75.35% Adobe RGB
Anti-glare, 3 ms response rate
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
8 GB GDDR6 SDRAM
Video System Features
NVIDIA Optimus
Gaming
Camera
Yes - 720p
Sound
Stereo speakers, array microphone
Input
Keyboard, touchpad
Keyboard Backlight
Yes (RGB)
Numeric Keypad
4 RGB zones
Communications
Wireless
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
66 Wh
AC Adapter
Input
Output
230 Watt, 19.5 V, 11.8 A
Connections & Expansion
USB-C 3.1 Gen 2 , 2 x USB 3.1 Gen 1 , USB 3.1 Gen 2 , Mini DisplayPort , HDMI , Headphone/microphone combo jack , LAN
Memory Card Reader
Yes (SD Card)
Black, gun metal
System password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, palm rest label, 3D ROG sculpture
2.4 kg
