ROG Strix Impact II is a lightweight, ambidextrous gaming mouse that delivers smooth action and superb flexibility. It features pivoted buttons and a soft-rubber cable for fast, tactile clicks and unhindered glides. There's also a 6,200 dpi sensor for pinpoint accuracy. As well, Impact II is equipped with an exclusive, push-fit switch socket design to extend its lifespan, and a four-level adjustable DPI switch that makes it easy to vary sensitivity to match the way you play, and a semi-transparent cover for a final touch of style.
Precise and accurate sidearm
Asus collaborated with professional gamers in the design of ROG Strix Impact II, resulting in ambidextrous ergonomics that are optimized for performance play and a comfortable grip, in a mere 79g frame. The 6,200 DPI sensor tracks at up to 220 ips and with a 1000 Hz polling rate, so you're assured high precision, fast response and accurate control - and all without a hint of lag. Impact II even includes five programmable buttons, allowing you to tailor control for your game or play style. -
Pivoted button mechanism
Shorter travel means quicker clicks, which is why Asus engineers equipped ROG Strix Impact II with pivoted buttons. The mechanism utilizes springs and metal hinges to balance the keys and minimize the distance between the buttons and switches. The upshot is minimal travel and rapid return, ensuring superb speed, responsiveness and consistency with every click. -
Soft-rubber cable
ROG Strix Impact II is engineered with soft-rubber cable. The soft-rubber construction and smooth finish minimizes snags to maximize your movements, meaning less drag for more frags. -
On-the-fly DPI button
ROG Strix Impact II is equipped with on-the-fly DPI button that lets you flip quickly between four different sensitivity settings, and within three customizable profiles. The integrated Aura RGB illumination even changes color to reflect your choice, providing an instant visual alert when you land on the desired sensitivity. -
Aura Sync RGB lighting
ROG Strix Impact II shines from top to tail, with Aura RGB lighting integrated into the logo, scroll wheel and front - with the leading LEDs projecting forward like headlights to illuminate your battlefield. The lighting can be customized using a near-endless spectrum of colors and a range of dynamic effects, and up to three profiles can be stored on board to take your preferences anywhere.
- ASUS ROG Strix Impact II - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- 6.2 cm x 12 cm x 3.86 cm
- 93 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 5
- Movement Resolution
- 16000 dpi
- Performance
- 400 ips tracking speed
- Programmable buttons, scrolling wheel, on-the-fly DPI switching, ASUS Aura Sync RGB LED
- OS Required
- Windows 10
- 3-year warranty
- Mouse
- Wireless Receiver
- 6.2 cm
- 12 cm
- 3.86 cm
- 93 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- Buttons Qty
- 5
- 16000 dpi
- Performance
- Included Accessories
- USB-C charging cable
- OS Required
- Windows 10
- Limited warranty - 3 years
