Experience incredible performance with the GL502's fast processor combined with advanced graphics. Powerful hardware gives you efficient performance for heavy gaming or productive multitasking such as live streaming and video editing.
On-the-go gaming
With a thin profile, the GL502 has a portable design that fits snugly in a messenger bag or backpack. Whether you're waiting for your flight, kicking back at a café, or at LAN tournament, you can game just about anywhere. -
Intelligent thermal design
The cooling system uses heat pipes and a dual-fan system to cool the CPU and GPU independently. This design maximizes cooling efficiency to give the GL502 the stability required for intense gaming marathons. -
Tactile keyboard
The GL502 has a specially designed chiclet gaming keyboard that offers you tactile keystrokes. It also features highlighted WASD keys so you know where your hands need to be. -
Filter out all ambient noise
The array microphones are designed to filter out ambient noise, which means that even if you're at LAN party or some other loud environment, your voice is still clearly heard.
- ASUS ROG Strix GL502VM FY410T - 15.6" - Intel Core i5 - 7300HQ - 12 GB RAM - 128 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7300HQ / 2.5 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 12 GB DDR4 (1 x 4 GB + 8 GB (soldered))
- Storage
- 128 GB SSD + 1 TB HDD / 7200 rpm
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 1060
- Video Memory
- 3 GB GDDR5 SDRAM
- VR Ready
- Gaming
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 4-cell
- Black
- 39 cm x 26.6 cm x 2.35 cm
- 2.24 kg
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - parts and labour - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7300HQ / 2.5 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM175
- Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 12 GB (1 x 4 GB + 8 GB (soldered))
- Max RAM Supported
- 24 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 128 GB SSD M.2 SATA 6Gb/s
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 7200 rpm
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72% NTSC
- Anti-glare, WideView
Audio & Video
- Graphics Processor
- Video Memory
- 3 GB GDDR5 SDRAM
- Video System Features
- NVIDIA G-SYNC
- VR Ready
- Gaming
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower
Input
- Keyboard, touchpad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 64 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 180 Watt, 19 V, 9.5 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , Mini DisplayPort , HDMI , 3 x USB 3.0 , LAN , USB-C Gen 2 (supports Thunderbolt)
- Memory Card Reader
- 2 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Black
- Case Material
- Aluminum, plastic
- System password, hard drive password, Hyper Cool Duo-Copper cooling system
- Included Accessories
- Power adapter
- 2.24 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
