Asus ROG Strix Core i5-9300H 16GB 512SSD GTX 1660Ti 15.6" Win 10
Quicklinx: FFQQWS00 Mfr#: G531GU-AL315T
Display Size: 15.6in
Processor Model: I5-9300H
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i5
Hurry, only 1 left in stock!
£1,037.01 ex VAT
£1,244.41 inc VAT
The ROG Strix G531 wraps key elements of a great gaming laptop in carefully designed chassis filled with intelligent cooling technology. Powerful components under the hood delivers smooth performance in a wide range of games. You still get a comfortable keyboard tuned for gaming, stronger Wi-Fi via ROG RangeBoost, and easy personalization with Aura Sync RGB lighting.
  • Heart of cold
    Laptops can struggle to hold high clock speeds with sustained workloads. Their cooling systems can easily clog with dust over time, which compromises efficiency and makes faster frequencies even more difficult to maintain. ROG's intelligent cooling philosophy helps the Strix G avoid these issues by mixing the right hardware and software for the system configuration and scenario at hand.
  • Work it out
    The Strix G's gaming prowess is balanced by serious brains with a fast processor. The CPU can reach turbo speeds, ensuring excellent performance with most games and applications.
  • Make every keystroke count
    The Strix G's keyboard has a familiar desktop-style layout that helps you feel right at home no matter where you are. Dedicated hotkeys provide convenient access to volume controls and microphone mute, while strategic spacing between the function keys makes common shortcuts faster to find. Highlighted WASD keys identify crucial controls, offset directional keys speed up navigation, and the extended space bar is easier to hit with your thumb.
ASUS ROG Strix G531GU AL315T - 15.6" - Core i5 9300H - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i5 (9th Gen) 9300H / 2.4 GHz (4.1 GHz) / 8 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
512 GB SSD NVMe
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce GTX 1660 Ti / Intel UHD Graphics 630
Video Memory
6 GB GDDR6 SDRAM
Keyboard Backlight
Yes (RGB)
802.11ac, Bluetooth 5.0, Gigabit Ethernet
4-cell
36 cm x 27.5 cm x 2.58 cm
2.4 kg
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Chipset
Mobile Intel HM370
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
Slots Qty
2
Storage
Main Storage
512 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Bezel Type
Raised
Anti-glare, 45% NTSC colour gamut, 120 Hz refresh rate, 67% sRGB colour gamut, 170° viewing angle, 50% Adobe RGB colour gamut
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
6 GB GDDR6 SDRAM
Video System Features
NVIDIA Optimus
Sound
Stereo speakers, array microphone
Input
Keyboard, touchpad
Keyboard Backlight
Yes (RGB)
Communications
Wireless
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
66 Wh
AC Adapter
Input
Output
230 Watt, 19.5 V, 11.8 A
Connections & Expansion
Headphone/microphone combo jack , 3 x USB 3.1 Gen 1 , USB-C 3.1 Gen 2/DisplayPort 1.4 , HDMI , LAN
Case Material
Polycarbonate, ABS plastic
System password
Power adapter
2.4 kg
Optical Storage: None
Graphics: NVIDIA GeForce GTX 1660 Ti / Intel UHD Graphics 630
Hard Drive Type: SSD
Type: Gaming Laptop
Brand: Asus
Price Range Ex VAT: 1000 - 1500
