The ROG Strix G531 wraps key elements of a great gaming laptop in carefully designed chassis filled with intelligent cooling technology. Powerful components under the hood delivers smooth performance in a wide range of games. You still get a comfortable keyboard tuned for gaming, stronger Wi-Fi via ROG RangeBoost, and easy personalization with Aura Sync RGB lighting.
Heart of cold
Laptops can struggle to hold high clock speeds with sustained workloads. Their cooling systems can easily clog with dust over time, which compromises efficiency and makes faster frequencies even more difficult to maintain. ROG's intelligent cooling philosophy helps the Strix G avoid these issues by mixing the right hardware and software for the system configuration and scenario at hand. -
Work it out
The Strix G's gaming prowess is balanced by serious brains with a fast processor. The CPU can reach turbo speeds, ensuring excellent performance with most games and applications. -
Make every keystroke count
The Strix G's keyboard has a familiar desktop-style layout that helps you feel right at home no matter where you are. Dedicated hotkeys provide convenient access to volume controls and microphone mute, while strategic spacing between the function keys makes common shortcuts faster to find. Highlighted WASD keys identify crucial controls, offset directional keys speed up navigation, and the extended space bar is easier to hit with your thumb.
- ASUS ROG Strix G531GU AL315T - 15.6" - Core i5 9300H - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i5 (9th Gen) 9300H / 2.4 GHz (4.1 GHz) / 8 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 512 GB SSD NVMe
- Optical Drive
- No optical drive
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 1660 Ti / Intel UHD Graphics 630
- Video Memory
- 6 GB GDDR6 SDRAM
- Keyboard Backlight
- Yes (RGB)
- Networking
- 802.11ac, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 4-cell
- Black
- 36 cm x 27.5 cm x 2.58 cm
- 2.4 kg
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM370
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Slots Qty
- 2
Storage
- Main Storage
- 512 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare, 45% NTSC colour gamut, 120 Hz refresh rate, 67% sRGB colour gamut, 170° viewing angle, 50% Adobe RGB colour gamut
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 6 GB GDDR6 SDRAM
- Video System Features
- NVIDIA Optimus
- Sound
- Stereo speakers, array microphone
Input
- Keyboard, touchpad
- Yes (RGB)
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 66 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 230 Watt, 19.5 V, 11.8 A
Connections & Expansion
- Headphone/microphone combo jack , 3 x USB 3.1 Gen 1 , USB-C 3.1 Gen 2/DisplayPort 1.4 , HDMI , LAN
- Black
- Case Material
- Polycarbonate, ABS plastic
- System password
- Included Accessories
- Power adapter
- 2.4 kg
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.49 | in stock |
£1,198.06
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£1,114.07
