ROG Spatha has a total of 12 programmable buttons, including six thumb buttons, to give you intuitive command and control. It fits perfectly in your hand, and has been ergonomically-designed to give you tactile feedback and response. Gaming mouse buttons take a lot of punishment, and that's why the buttons on ROG Spatha feature durable switches with a 20-million-click lifespan. The switchable socket design allows for easy customization too. ROG Spatha comes with fully-programmable thumb buttons with Alps switches to give you tactile feedback. The six buttons are arranged to resemble the iconic ROG eye and are designed to provide intuitive control and feel.
ROG Spatha utilizes a high-speed wireless connection for high data throughput and low latency to ensure all your movements are tracked accurately. And once the battery runs out, you can continue using it while charging, all without losing response and performance. ROG Spatha has an aggressive angular design that stands out. You can even customize the LED light effects on the scroll wheel, side buttons and ROG logo from a wide range of colors. Customize user profiles, lighting effects, and program macros via the intuitive ROG Armory dashboard.
Twelve programmable buttons
ROG Spatha has a total of 12 programmable buttons, including six thumb buttons, to give you intuitive command and control. It fits perfectly in your hand, and has been ergonomically-designed to give you tactile feedback and response. -
Customizable switch socket design
Gaming mouse buttons take a lot of punishment, and that's why the buttons on ROG Spatha feature durable Omron switches with a 20-million-click lifespan. The switchable socket design allows for easy customization too. -
Six programmable thumb buttons
ROG Spatha comes with fully-programmable thumb buttons with Alps switches to give you tactile feedback. The six buttons are arranged to resemble the iconic ROG eye and are designed to provide intuitive control and feel. -
Wireless and wired - it's your choice
ROG Spatha utilizes a high-speed wireless connection for high data throughput and low latency to ensure all your movements are tracked accurately. And once the battery runs out, you can continue using it while charging, all without losing response and performance. -
Customizable light effects across three zones
ROG Spatha has an aggressive angular design that stands out. You can even customize the LED light effects on the scroll wheel, side buttons and ROG logo from a wide range of colors. -
Prepare for battle with ROG Armory
Customize user profiles, lighting effects, and program macros via the intuitive ROG Armory dashboard. -
Swap switchable socket
ROG Spatha features an easy-swap switchable socket design for easy upgrades. All you have to do is unscrew the four bottom screws with the bundled screwdriver to release the top cover and gain access to the sockets.
- ASUS ROG Spatha - mouse - USB, 2.4 GHz - titanium black
- Mouse
- Connectivity Technology
- Wireless, wired - USB, 2.4 GHz
- Titanium black
- Orientation
- Right-handed
- 8.9 cm x 13.7 cm x 4.5 cm
- 178.5 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 12
- Movement Resolution
- 8200 dpi
- Performance
- 30 G maximum acceleration, 150 inches per second, polling rate: 2000 Hz
- Built-in flash memory, OMRON switches, 2 DPI levels, Alps scroll wheel encoder, RGB colour LED
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
- Designed For
- ASUSPRO P1; 14; 15; ExpertBook B9450FA; ROG Strix G GL531GU; ROG Strix G15; G17; ROG Zephyrus G14; M15; S15; S17; TUF Gaming A15; A17; F15; F17; FX505DT; FX505DV; FX705DT; FX705DY; TUF505DV; VivoBook 14; 15; 17; VivoBook Flip 12 TP202NA; 14 TP401MA; X543UA; ZenBook 13; 14
- Mouse
- Wireless Receiver
- Orientation
- Right-handed
- 8.9 cm
- 13.7 cm
- 4.5 cm
- 178.5 g
- Titanium black
Input Device
- Wireless, wired
- Interface
- USB, 2.4 GHz
- Laser
- Buttons Qty
- 12
- 8200 dpi
- Performance
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Carrying case, USB cable (2 m), 2 Omron switches, USB cable (1 m), 2 ROG logo stickers, star-head screwdriver
- Software Included
- ROG Armoury
- OS Required
- Designed For
- ASUSPRO P1 P1440FA-C53P , ASUS 14 X409JA-EK026T , ASUS 15 M509BA-EJ183T, M509DA-EJ025, M509DA-EJ1062T, S509DA-EJ029T , ASUS ExpertBook B9450FA BM0445R , ASUS ROG Strix G GL531GU WB53 , ASUS ROG Strix G15 G512LU-AL041T, G512LW-WS74 , ASUS ROG Strix G17 G712LU-H7015T, G712LU-H7023T, G712LV-EV023T, G712LV-H7074T, G712LV-H7077T , ASUS ROG Zephyrus G14 GA401II-025T, GA401II-HE092T, GA401II-HE109T, GA401IU-HE002 , ASUS ROG Zephyrus M15 GU502LV-HC049T, GU502LW-HN138T , ASUS ROG Zephyrus S15 GX502LWS-HF020T , ASUS ROG Zephyrus S17 GX701LWS-EV029T, GX701LWS-EV076T, GX701LWS-HG052R, GX701LWS-HG052T, GX701LXS-HG007T , ASUS TUF Gaming A15 FX506II-HN111T, FX506IU-HN222T, FX506IU-HN296T , ASUS TUF Gaming A17 FX706II-AU031T , ASUS TUF Gaming F15 FX506IH-BQ224T, FX506LH-BQ030, FX506LH-HN111T, FX506LI-BQ052T, FX506LI-HN023T, FX506LI-HN222T, FX506LU-HN037T, FX506LU-HN333T , ASUS TUF Gaming F17 FX706LI-AU022T, FX706LI-H7010T , ASUS TUF Gaming FX505DT BQ000T, BQ137T, HN549T, HN565T, HN571T, WB72 , ASUS TUF Gaming FX505DV , ASUS TUF Gaming FX705DT , ASUS TUF Gaming FX705DY , ASUS TUF505DV HN232T , ASUS VivoBook 14 K413FA-EK695T, M413IA-EB371T , ASUS VivoBook 15 F512JA-EJ011T, X512DA-EJ1458T, X512FB-BR468T, X512FJ-EJ529T, X512JA-BQ147T , ASUS VivoBook 17 M712DA-AU311T, X712FA-AU606R, X712FA-AU642T, X712FA-AU643T, X712FA-AU848T , ASUS VivoBook Flip 12 TP202NA CMSP, QMSP, XS04 , ASUS VivoBook Flip 14 TP401MA CMSP, QMSP , ASUS X543UA GO3047T, GQ2636T , ASUS ZenBook 13 UX334FAC-A4113T , ASUS ZenBook 14 UM433IQ-PURE5, UX425JA-BM090R, UX431FA-AN168T, UX433FAC-AI258R, UX434FAC-A5188T
