Asus ROG Sica
Compact ambidextrous mouse with enhanced click resistance
Designed with input from pro gamers for guaranteed performance and aesthetics
Left and right buttons are separate from the main body for improved responsiveness
Easy-swap switch socket for customizable click resistance
Built-in flash memory to save your favorite profiles
Exclusive ROG Armoury interface for easy customization of buttons, performance, and light settings.
5000 DPI, 130 ips, 30g acceleration and 1000Hz USB polling rate for swift, pixel-precise mouse tracking
ROG Sica is crafted to withstand the demands of marathon MOBA gaming, and is designed with input from pro-gaming teams. This ambidextrous 5000 DPI optical gaming mouse optimizes click responsiveness by having the buttons independent of the mouse body, and is especially suited for those with a fingertip grip. Its exclusive easy-swap switch socket design even lets you customize click resistance. ROG makes sure you get the most out of your games.
ROG Sica features left and right buttons that are separated from the mouse body. This reduces the click force and travel distance required for button actuation to give faster and more tactile button response.
ROG Sica features an exclusive easy-swap switch socket design for easy upgrades. All you have to do is unscrew two bottom screws to release the top cover to gain access to the sockets. And from here, it's simply a matter of swapping out the switches for customized click resistance.
ROG Sica has a 5000 DPI PMW3310 optical sensor that's adjustable in increments of 50 DPI for extreme precision. Capable of tracking speeds of up to 130-inches per second and 30g of acceleration, ROG Sica lets you strike at enemies with blinding speed and pixel-perfect accuracy.
ROG Sica has built-in flash memory to store your favorite profiles; it also features the innovative Armoury software – letting you customize button functions, performance and logo light effects to get the most out of ROG Sica.
Since the debut of our magnificent Maximus motherboard, ROG has steadily expanded its gaming line-up to ensure you get the most out of your games. Today, ROG Sica joins our gaming empire. The Sica was a short, curved sword used in Ancient Rome. It proved to be a formidable weapon, and was effective in battle. Now it's your turn to wield the Sica to write your own legendary chapter in gaming.
Responsive buttons
ROG Sica features left and right buttons that are separated from the mouse body. This reduces the click force and travel distance required for button actuation to give faster and more tactile button response. -
Exclusive easy-swap switch socket
ROG Sica features an exclusive easy-swap switch socket design for easy upgrades. All you have to do is unscrew two bottom screws to release the top cover to gain access to the sockets. And from here, it's simply a matter of swapping out the switches for customized click resistance. -
Glide with extreme precision
ROG Sica has a 5000 DPI optical sensor for extreme precision. Capable of tracking high speeds, ROG Sica lets you strike at enemies with blinding speed and pixel-perfect accuracy.
- ASUS ROG Sica - mouse - USB - steel grey
- Mouse
- Connectivity Technology
- Wired - USB
- Steel grey
- Orientation
- Right and left-handed
- 6.2 cm x 11.5 cm x 3.9 cm
- 117 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 5000 dpi
- Performance
- 30 G maximum acceleration, up to 130 inches per second
- Teflon feet, built-in flash memory, easy-swap switch socket, separate right/left buttons, 1000 Hz polling rate
- OS Required
- Microsoft Windows 7 / 8 / 8.1
- Designed For
- ASUSPRO P1; 14; 15; ExpertBook B9450FA; ROG Strix G15; G17; ROG Zephyrus G14; S17; TUF Gaming A15; A17; F15; F17; FX505DT; FX705DT; FX705DY; TUF505DV; VivoBook 14; 15; 17; VivoBook Flip 12 TP202NA; 14 TP401MA; X543UA; ZenBook 13; 14
- Mouse
- Orientation
- 6.2 cm
- 11.5 cm
- 3.9 cm
- 117 g
- Steel grey
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 5000 dpi
- Performance
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- 2 ROG logo stickers
- Software Included
- ROG Armoury
- OS Required
- Designed For
- ASUSPRO P1 P1440FA-C53P , ASUS 14 X409JA-EK026T , ASUS 15 M509BA-EJ183T, M509DA-EJ025, M509DA-EJ1062T, S509DA-EJ029T , ASUS ExpertBook B9450FA BM0445R , ASUS ROG Strix G15 G512LU-AL041T, G512LW-WS74 , ASUS ROG Strix G17 G712LU-H7015T, G712LU-H7023T, G712LV-EV023T, G712LV-H7074T, G712LV-H7077T , ASUS ROG Zephyrus G14 GA401II-025T, GA401II-HE092T, GA401II-HE109T, GA401IU-HE002 , ASUS ROG Zephyrus S17 GX701LWS-EV029T, GX701LWS-EV076T, GX701LWS-HG052R, GX701LXS-HG007T , ASUS TUF Gaming A15 FX506II-HN111T, FX506IU-HN222T, FX506IU-HN296T , ASUS TUF Gaming A17 FX706II-AU031T , ASUS TUF Gaming F15 FX506IH-BQ224T, FX506LH-BQ030, FX506LH-HN111T, FX506LI-BQ052T, FX506LI-HN023T, FX506LI-HN222T, FX506LU-HN037T, FX506LU-HN333T , ASUS TUF Gaming F17 FX706LI-AU022T, FX706LI-H7010T , ASUS TUF Gaming FX505DT BQ000T, BQ137T, HN549T, HN565T, HN571T, WB72 , ASUS TUF Gaming FX705DT , ASUS TUF Gaming FX705DY , ASUS TUF505DV HN232T , ASUS VivoBook 14 K413FA-EK695T, M413IA-EB371T , ASUS VivoBook 15 F512JA-EJ011T, X512DA-EJ1458T, X512FB-BR468T, X512FJ-EJ529T, X512JA-BQ147T , ASUS VivoBook 17 M712DA-AU311T, X712FA-AU606R, X712FA-AU642T, X712FA-AU643T, X712FA-AU848T , ASUS VivoBook Flip 12 TP202NA CMSP, QMSP, XS04 , ASUS VivoBook Flip 14 TP401MA CMSP, QMSP , ASUS X543UA GO3047T, GQ2636T , ASUS ZenBook 13 UX334FAC-A4113T , ASUS ZenBook 14 UM433IQ-PURE5, UX425JA-BM090R, UX431FA-AN168T, UX433FAC-AI258R, UX434FAC-A5188T
