With a built-in Aura RGB-strip header and easy lighting controls, it's never been easier to light up your rig - and your LAN parties! Rampage V Edition 10 includes the amazing Aura lighting-control utility to cast stunning multi-color glows across your gaming rig, via the motherboard's powerful built-in RGB LEDs or attached RGB strips, or both - and in perfect synchronization! Fire up Aura and then enjoy the creative freedom of nine different lighting schemes. You're even able to sync your lighting style with the ever-growing portfolio of Aura-capable gear.
Best gaming lighting
With a built-in Aura RGB-strip header and easy lighting controls, it's never been easier to light up your rig - and your LAN parties! Rampage V Edition 10 includes the amazing Aura lighting-control utility to cast stunning multi-color glows across your gaming rig, via the motherboard's powerful built-in RGB LEDs or attached RGB strips, or both - and in perfect synchronization! -
Aura lighting control
Fire up Aura and then enjoy the creative freedom of nine different lighting schemes. You're even able to sync your lighting style with the ever-growing portfolio of Aura-capable gear. -
Aura 4-pin Aura RGB-strip header
Forget the faff of external RGB controllers! With ROG's Aura RGB-strip header, it's quick and easy to cast brilliant colors across your rig and room: just slide standard 12V RGB strips onto the 4-pin Aura RGB-strip header, then weave your lighting any way you like. And, ROG has teamed up with well-known strip-makers and case manufacturers for great synchronized effects and best compatibility - so you'll light up as easy as RGB wherever you see the Aura Ready logo! -
Best overclocking armory
Greater performance means smoother gameplay - and that means more chances to win. With the best overclocking (OC) design, UEFI BIOS and intuitive OC gadget and utility, you'll enjoy unmatched performance - coupled with an exclusive cooling design ensures your system never breaks a sweat. -
Save more time, break more records
ROG understands overclockers better than any other manufacturer - so Rampage V Edition 10 includes loads of hardware-level controls to aid your overclocking adventures, including DIMM and PCIe switches, Safe Boot and ReTry buttons. They're quick, easy and real time-savers!
- ASUS ROG RAMPAGE V EDITION 10 - motherboard - extended ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - extended ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition, Core i7
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 10 x SATA-600 (RAID), 1 x M.2, 1 x U.2 port
- USB / FireWire Ports
- 2 x USB-C + 2 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 2133 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3333 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
- Audio Codec
- SupremeFX
- DTS Connect, High Definition Audio
LAN
- Network Controller
- Intel I211-AT / I218V
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (40-lane CPU (dual x16 mode; triple: x16, x8, x8 mode; quad: x16, x8, x8, x8 or x8, x8, x8, x8 mode), 28-lane CPU (dual x16, x8 mode; triple: x8, x8, x8 mode)) , 1 x PCIe 2.0 x4 , 1 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 10 x 7pin SATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 1 x M.2, 1 x U.2
- RAID Features
- Intel Smart Response Technology
- 2 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 4 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 2 x USB 3.1 , 2 x USB-C
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x audio - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, NVIDIA SLI Technology Support, ASUS Q-Design, Q-DIMM, Q-LED, ProbeIt, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), NVIDIA 3-way SLI Technology Support, ASUS Extreme Tweaker, Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, NVIDIA 4-way SLI Technology Support, ASUS ROG Extreme OC, Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Wi-Fi GO!, AMD 4-way CrossFireX technology support, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), Dual Intelligent Processors 5, LANGuard, Sonic Radar II, USB 3.1 Boost, Sonic Studio II, KeyBot II, GameFirst IV, ROG SSD Secure Erase, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS SafeSlot
- Included Accessories
- I/O back plate, ROG cable lables, 1 x M.2 screw, ASUS 3T3R Wi-Fi moving aerials, fan extension card, ROG fan stickers, SupremeFX Hi-Fi Kit, USB stick, ROG coasters
- Cables Included
- 10 x Serial ATA cable , 1 x SLI bridge , 1 x 3-way SLI bridge , 1 x 4-way SLI bridge
- Software Included
- Drivers & Utilities, Kaspersky Anti-Virus (1 year subscription), ASUS AI Charger+, ROG CPU-Z, ASUS AI Suite III, ROG RAMDisk, ASUS Turbo App, DAEMON Tools Pro Standard (1 year), PC Cleaner, Media Streamer, HyStream, ASUS RAMCache, ASUS EZ Flash 3, ROG Aura, ROG GameFirst IV
- Plug and Play, ACPI 5.0
- 30.5 cm
- 27.2 cm
