Asus ROG Pugio Mouse
Quicklinx: D86YWS00 Mfr#: 90MP00L0-B0UA00
ROG Pugio is an ambidextrous gaming mouse that offers ultimate customizability to meet the needs of hardcore gamers. Its configurable side buttons let you decide on your own side button layout, while exclusive push-fit switch sockets offer variable click resistance. The push-fit design makes it easy to replace worn out switches to extend the lifespan of the mouse. The Pugio features stunning, aggressive aesthetics to match its performance - including angular ASUS Aura RGB light channels with Aura Sync support.
  • Configurable side buttons
    Ambidextrous mice with side buttons usually feature a mirrored button layout to accommodate both right- and left-handed gamers. The drawback of this design is that it often results in side button misclicks. Even with the buttons disabled, they can still be distracting. With the ROG Pugio, there's no need to change your grip style to avoid the buttons. The Pugio has configurable magnetic side buttons on both flanks to give you a truly ambidextrous and ergonomic gaming mouse. Simply swap the buttons out and replace them with the side button covers.
  • Exclusive push-fit switch socket design
    ROG Pugio features an exclusive push-fit switch socket design that allows you to easily change switches to vary click resistance.
  • Dominating aesthetics
    ROG Pugio will be the centerpiece of your battle station. With a quality gunmetal-gray finish, underside engravings, Mayan-inspired rubber side panels for a secure and comfortable grip, and angular ASUS Aura RGB light channels, the Pugio is a stunning weapon from every angle.
  • Durable switches
    Mouse buttons and switches - especially switches on gaming mice - take the most abuse. With high-quality Omron mouse switches, the ROG Pugio is built to last.
  • Advanced optical sensor
    Every strike is critical. At the heart of ROG Pugio is an optical sensor that provides you with the accuracy and precision needed to take down the opponent.
  • Separate button design
    The ROG Pugio has a separate button design that lowers the actuation force and travel distance required for each click, so you'll enjoy faster and more tactile button response.
ASUS ROG Pugio - mouse - USB
Mouse
Wired - USB
6.8 cm x 12 cm x 3.7 cm
103 g
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
7200 dpi
Performance
30 G maximum acceleration, 150 inches per second
OMRON switches, separate right/left buttons, ASUS Aura Sync RGB LED
Microsoft Windows 7 / 8.1 / 10
ASUSPRO P1; 14; 15; ExpertBook B9450FA; ROG Strix G GL531GU; ROG Strix G15; G17; ROG Zephyrus G14; M15; S15; S17; TUF Gaming A15; A17; F15; F17; FX505DT; FX505DV; FX705DT; FX705DY; TUF505DV; VivoBook 14; 15; 17; VivoBook Flip 12 TP202NA; 14 TP401MA; X543UA; ZenBook 13; 14
Mouse
6.8 cm
12 cm
3.7 cm
103 g
Input Device
Wired
USB
Optical
Buttons Qty
7
Movement Resolution
7200 dpi
Performance
2 Omron switches, ROG pouch, ROG logo sticker
ASUSPRO P1 P1440FA-C53P , ASUS 14 X409JA-EK026T , ASUS 15 M509BA-EJ183T, M509DA-EJ025, M509DA-EJ1062T, S509DA-EJ029T , ASUS ExpertBook B9450FA BM0445R , ASUS ROG Strix G GL531GU WB53 , ASUS ROG Strix G15 G512LU-AL041T, G512LW-WS74 , ASUS ROG Strix G17 G712LU-H7015T, G712LU-H7023T, G712LV-EV023T, G712LV-H7074T, G712LV-H7077T , ASUS ROG Zephyrus G14 GA401II-025T, GA401II-HE092T, GA401II-HE109T, GA401IU-HE002 , ASUS ROG Zephyrus M15 GU502LV-HC049T, GU502LW-HN138T , ASUS ROG Zephyrus S15 GX502LWS-HF020T , ASUS ROG Zephyrus S17 GX701LWS-EV029T, GX701LWS-EV076T, GX701LWS-HG052R, GX701LWS-HG052T, GX701LXS-HG007T , ASUS TUF Gaming A15 FX506II-HN111T, FX506IU-HN222T, FX506IU-HN296T , ASUS TUF Gaming A17 FX706II-AU031T , ASUS TUF Gaming F15 FX506IH-BQ224T, FX506LH-BQ030, FX506LH-HN111T, FX506LI-BQ052T, FX506LI-HN023T, FX506LI-HN222T, FX506LU-HN037T, FX506LU-HN333T , ASUS TUF Gaming F17 FX706LI-AU022T, FX706LI-H7010T , ASUS TUF Gaming FX505DT BQ000T, BQ137T, HN549T, HN565T, HN571T, WB72 , ASUS TUF Gaming FX505DV , ASUS TUF Gaming FX705DT , ASUS TUF Gaming FX705DY , ASUS TUF505DV HN232T , ASUS VivoBook 14 K413FA-EK695T, M413IA-EB371T , ASUS VivoBook 15 F512JA-EJ011T, X512DA-EJ1458T, X512FB-BR468T, X512FJ-EJ529T, X512JA-BQ147T , ASUS VivoBook 17 M712DA-AU311T, X712FA-AU606R, X712FA-AU642T, X712FA-AU643T, X712FA-AU848T , ASUS VivoBook Flip 12 TP202NA CMSP, QMSP, XS04 , ASUS VivoBook Flip 14 TP401MA CMSP, QMSP , ASUS X543UA GO3047T, GQ2636T , ASUS ZenBook 13 UX334FAC-A4113T , ASUS ZenBook 14 UM433IQ-PURE5, UX425JA-BM090R, UX431FA-AN168T, UX433FAC-AI258R, UX434FAC-A5188T
