Asus ROG MAXIMUS X HERO Intel Z370 S1151 DDR4 Dual M.2 USB 3.1 Gen2
Quicklinx: D5PFWS00 Mfr#: ROG MAXIMUS X HERO
Asus ROG MAXIMUS X HERO Intel Z370 DDR4 4133mhz Dual M.2 USB 3.1
  • AURA lighting control
    A well-tuned enthusiast system deserves a matching aesthetic. ASUS Aura offers full RGB lighting control with a variety of functional presets for the built-in RGB LEDs as well as strips connected to the onboard RGB headers.
  • RGB lighting perfected
    ROG Maximus X Hero features a duo of onboard 5050 RGB headers and an addressable header that can be connected to compatible lighting strips, fans, coolers, and PC cases, creating a great world of illumination possibilities
  • Exclusive 3D Mount for easy installation
    Dedicated 3D Mount on the motherboard makes fitting 3D-printed parts easy. Using the same screws as M.2 drives and standard motherboard mounting holes, you can easily add nameplates, cable covers, or an M.2 fan holder in a matter of moments.
  • M.2 heatsink
    ROG Maximus X Hero is equipped with a stylish, angular M.2 heatsink that keeps your SSD cool. By efficiently dissipating heat away from the M.2 area, ROG Maximus X Hero minimizes the possibility of the performance-sapping throttling that can happen when drives become too warm. The heatsink's angular design adds an eye-catching touch to any build, while the T-sensor detects temperatures in the vital M.2 area for instant monitoring.
  • Intel Ethernet
    Featuring the advanced Intel Ethernet for faster, smoother gaming. Intel Ethernet controllers have a natural synergy with their CPUs and chipsets, reducing processor overhead and offering exceptionally high TCP and UDP throughput, so there's more power for games and other tasks.
  • Let your SSD scream at top speed
    With x4 PCI Express 3.0/2.0 bandwidth, M.2 supports up to 32 Gbit/s data-transfer speeds. It is the perfect choice for an operating system or application drive, making your whole PC or professional apps work as fast as possible.
  • 5-Way Optimization
    One click takes care of all that complex tuning. ASUS 5-Way Optimization makes your PC smart. It dynamically optimizes essential aspects of the system, providing overclocking and cooling profiles that are tailored for your rig.
  • SupremeFX
    ROG's awesome SupremeFX audio technology has leveled up, delivering an exceptional 113 dB signal-to-noise ratio on the line-in connection! The low-dropout regulator for cleaner power delivery was added to the SupremeFX S1220 codec, an ESS Sabre Hi-Fi ES9023P digital-to-analog converter for superior front-panel output, and a Texas Instruments RC4850 op-amp for high gain with low distortion - which all adds up to audio that envelops you as never before.
  • Overwolf
    Overwolf is a clever, unobtrusive overlay that keeps you in the game and allows you to browse the web, email, IM, stream or record while you play. The overlay features color-matched ROG skins that show you're part of an elite pack.
ASUS ROG MAXIMUS X HERO - motherboard - ATX - LGA1151 Socket - Z370
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (1 x USB 3.1 Gen 2 + 2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
3-year warranty
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 2800 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
SupremeFX (S1220)
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
1 x HDMI , 1 x DisplayPort , 4 x USB 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 2 x USB 2.0
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x USB 3.1 Gen 2 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Extreme Tweaker, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, ASUS ROG Extreme OC, Q-Code, SupremeFX Shielding technology, AMD 3-way CrossFireX technology support, Disk Unlocker, dual headphone amplifiers, Dual Intelligent Processors 5, LANGuard, KeyBot II, GameFirst IV, ROG SSD Secure Erase, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS SafeSlot, 3D printing friendly, Intel Optane Memory Ready, Sonic Radar III, Sonic Studio III, Mem TweakIt, ASUS PRO Clock II Technology, M.2 heatsink
1 x M.2 screw, ROG coasters, 3D printing mount package, CPU installation tool, 2 RGB (RGBW) LED strip extension cables, MOS cooling kit, ROG big sticker
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ROG CPU-Z, ASUS AI Suite III, ROG RAMDisk, ASUS Turbo App, Overwolf, ASUS EZ Flash 3, ROG Aura, ROG GameFirst IV, ASUS ROG RAMCache II, ROG CloneDrive
Plug and Play
30.5 cm
24.4 cm
Limited warranty - parts and labour - 3 years
