Asus ROG GLADIUS Gaming Mouse
Quicklinx: B10JWS00 Mfr#: P501-1A
Recommended Use: Gaming
Type: Mouse
Wired / Wireless: Wired
Colour: Steel grey
Compatibility: PC
£52.56 ex VAT
£63.07 inc VAT
Introducing the new ROG GLADIUS Gaming Mouse
Crafted Comfort, Customizable Clicks!
ROG Gladius is an optical wired gaming mouse engineered with perfect right-hand ergonomics for first-person shooter (FPS) mastery! Smooth-touch materials stay cool in your hand and high-quality Mayan-patterned rubber secures your grip. With exclusive switch socket design for customizable click resistance, two-level DPI switch, 'slide-to-press' side switches and a 6400dpi optical sensor that tracks up to 200 inches per second and 50g acceleration, the battlefield is at your mercy. Detach the cable for carrying around -- lock and load
  • Epic ergonomics and aesthetics
    World top pro gamers involved in design stage, back and forth to ensure the best ergonomics! The fine-tuned curves make Gladius the perfect fit for all grip-types.
  • Unbeatable performance
    Gladius is manufactured with high-quality mouse switches that are good for at least 20-million presses, so you'll enjoy accurate clicks from buttons that just keep going. Forget soldering hassles when changing mouse switches, as ROG's exclusive socket design means you pick and fit your perfect click resistance and recoil with one simple push.
  • Best mobility
    Gladius comes with two USB cables. Leave the 2-meter cable on your desk for convenience and carry the 1-meter travel cable to LAN parties or internet caf├ęs - it takes just one touch to detach either cable!
  • Intuitive customization
    Gladius has built-in flash memory to store your favorite profile, so it's always by your side. It also features the innovative software - allowing you to create, customize, and store unlimited profiles on your PC! The Gladius software includes an intelligent surface-calibration tool for pixel-perfect precision. Gladius analyzes and learns the surface characteristics to hone the sensor's accuracy - and that means even better in-game responsiveness!
ASUS ROG Gladius - mouse
Wired USB 2.0
Tracking Resolution
6400 dpi optical sensor
Tracking Speed
200 ips
Tracking Acceleration
50 g
Responsiveness
1000 Hz polling rate
Switch
Omron D2FC-F-7N (20M)
Extra Japanese-made Omron D2F-01F included
Cable
2-meter braided USB cable
Extra 1-meter regular rubber USB cable
Operating System
Windows 8.1, Windows 8, Windows 7, Mac OS X (10.7-10.9)
Dimensions
L 126 x W 67 x H 45 mm
116g (without cable)
Package Contents
1 x 2-meter braided USB cable
1 x 1-meter regular rubber USB cable
2 x Japanese-made Omron switches
1 x ROG pouch
2 x ROG logo stickers
4 x mouse feet
Type: Mouse
Colour: Steel grey
Compatibility: PC
Brand: Asus
Price Range Ex VAT: 50 - 100
