ASUS RECO Classic Car Cam
is an in-car digital video recorder that features an f/2.0 aperture, 140-degree wide-angle lens for high quality Full HD 1080p video recording day and night, and in all weather conditions. A built-in G-sensor automatically triggers an emergency record function in the event of an accident.
- High Dynamic Range (HDR) technology for detailed images in limited visibility or high-contrast environments like dark tunnels or bright sunlight.
- Full HD 1920 x 1080p recording at 30 frames per second with 140-degree wide-angle lens to capture views of the sides of the vehicle and the road ahead.
- Built-in G-sensor triggers an emergency record function in the event of an accident, saving and locking down the latest footage in a separate file.
- Built-in safety features like forward collision and lane departure warning systems.
- Does not interfere with other in-car systems and is certified by numerous worldwide agencies.
- GPS-based speed camera detector* gives the driver audio and visual warnings as a reminder to maintain a safe driving speed.
*Only available in selected territories
Detailed Full HD in-car video recording
ASUS RECO Classic Car Cam is an in-car digital video recorder that features an f/2.0 aperture, 140-degree wide-angle lens for high quality Full HD 1080p video recording day and night, and in all weather conditions. A built-in G-sensor automatically triggers an emergency record function in the event of an accident.
Capturing detailed video, day or night
ASUS RECO Classic Car Cam uses High Dynamic Range (HDR) recording for detailed in-car videos in bright sunlight or dimly-lit environments. It achieves this by capturing and combining multiple exposures of the same scene - allowing you to pick out minor details like road signs and license plates in the resulting images.
Record in Full HD 1080p
ASUS RECO Classic Car Cam is powered by an Ambarella chipset and features the latest Omnivision CMOS sensor to let you record Full HD 1920 x 1080 resolution in-car videos at a smooth 30 frames per second.
The 140-degree wide-angle lens captures unobstructed views of the sides of the vehicle and the road ahead
Emergency record file protection
In the event of a collision, the built-in three-axis G-sensor triggers the emergency record function, saving a minute-long video (30 seconds prior to/after impact) and locking it down in a separate file so it won't be inadvertently deleted. There is also a manual emergency record button that allows you to save videos for every critical moment. You can save up to 10 emergency record clips without having to worry about recording over them.
Designed with road safety in mind
At speeds above 60km/h, ASUS RECO Classic Car Cam has a Lane Departure Warning System (LDWS) that gives you onscreen warnings and audio alerts if the vehicle veers outside road lane markings; while the Forward Collision Warning System (FCWS) lets you know if you're following too closely to the car ahead.
Speed camera detection
A GPS sensor notifies you of nearby speed cameras, and gives you audio and visual warnings as a reminder to maintain a safe driving speed*.
*only available in select territories
Easy setup
The compact ASUS RECO Classic Car Cam has a bracket mount which sticks on your windscreen, and comes with adhesive cable clips that effectively hide the cigarette lighter adapter cable.
No interference with other in-car devices
ASUS RECO Classic Car Cam does not interfere with other in-car systems and meets numerous global certification standards, including the China Compulsory Certificate mark (CCC Mark), CE mark, and the Taiwan Bureau of Standards, Metrology and Inspection.
ASUS RECO Classic Car Cam is an in-car digital video recorder that features an f/2.0 aperture, 140-degree wide-angle lens for high quality Full HD 1080p video recording day and night, and in all weather conditions. A built-in G-sensor automatically triggers an emergency record function in the event of an accident. -
ASUS RECO Classic Car Cam uses High Dynamic Range (HDR) recording for detailed in-car videos in bright sunlight or dimly-lit environments. It achieves this by capturing and combining multiple exposures of the same scene - allowing you to pick out minor details like road signs and license plates in the resulting images. -
ASUS RECO Classic Car Cam is powered by an Ambarella chipset and features the latest Omnivision CMOS sensor to let you record Full HD 1920 x 1080 resolution in-car videos at a smooth 30 frames per second. -
The 140-degree wide-angle lens captures unobstructed views of the sides of the vehicle and the road ahead. -
In the event of a collision, the built-in three-axis G-sensor triggers the emergency record function, saving a minute-long video (30 seconds prior to/after impact) and locking it down in a separate file so it won't be inadvertently deleted. There is also a manual emergency record button that allows you to save videos for every critical moment. You can save up to 10 emergency record clips without having to worry about recording over them. -
At speeds above 60km/h, ASUS RECO Classic Car Cam has a Lane Departure Warning System (LDWS) that gives you onscreen warnings and audio alerts if the vehicle veers outside road lane markings; while the Forward Collision Warning System (FCWS) lets you know if you're following too closely to the car ahead. -
Easy setup
- ASUS RECO Classic - dashboard camera
- Product Type
- Dashboard camera - 1080p
- Memory Card Slot
- microSD card
- Image Processor
- Ambarella
- Sensors
- G-sensor
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens f/2.0
- Focus Adjustment
- Focus free
- Display
- LCD display - 2"
- Incident Detection
- G-Sensor
- Supported Battery
- (included)
- Product Type
- Sensor Qty
- 1 CMOS
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Frame Rate (Max Resolution)
- 30 fps
- Image Processor
- Ambarella
- HDR Mode
- Auto HDR mode
- Sensors
- G-sensor
- Digital Video Format
- H.264, MOV
- 1920 x 1080
Exposure & White Balance
- Exposure Modes
- Automatic
- White Balance
- Automatic
Lens System
- Focus Adjustment
- Focus free
- Max View Angle
- 140 degree(s)
Additional Features
- Additional Features
- Audio recording, built-in speaker, date/time stamp
Dashboard Camera Features
- G-Sensor
- Lane Departure Warning System, Forward Collision Warning System
Display
- 2" LCD display
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Included Accessories
- Car power adapter, camera mounting kit, adhesive mount
- Battery Type
- Integrated
- Details
- (included)
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 64 GB
- 0 °C
- 60 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
