Asus Reco Classic Car DashCam with Full HD and Night Recording
Quicklinx: BSVZWS00 Mfr#: 90YU00I2-B01EA0
ASUS RECO Classic Car Cam
is an in-car digital video recorder that features an f/2.0 aperture, 140-degree wide-angle lens for high quality Full HD 1080p video recording day and night, and in all weather conditions. A built-in G-sensor automatically triggers an emergency record function in the event of an accident.
  • High Dynamic Range (HDR) technology for detailed images in limited visibility or high-contrast environments like dark tunnels or bright sunlight.
  • Full HD 1920 x 1080p recording at 30 frames per second with 140-degree wide-angle lens to capture views of the sides of the vehicle and the road ahead.
  • Built-in G-sensor triggers an emergency record function in the event of an accident, saving and locking down the latest footage in a separate file.
  • Built-in safety features like forward collision and lane departure warning systems.
  • Does not interfere with other in-car systems and is certified by numerous worldwide agencies.
  • GPS-based speed camera detector* gives the driver audio and visual warnings as a reminder to maintain a safe driving speed.
    *Only available in selected territories
Detailed Full HD in-car video recording
ASUS RECO Classic Car Cam is an in-car digital video recorder that features an f/2.0 aperture, 140-degree wide-angle lens for high quality Full HD 1080p video recording day and night, and in all weather conditions. A built-in G-sensor automatically triggers an emergency record function in the event of an accident.
Capturing detailed video, day or night
ASUS RECO Classic Car Cam uses High Dynamic Range (HDR) recording for detailed in-car videos in bright sunlight or dimly-lit environments. It achieves this by capturing and combining multiple exposures of the same scene - allowing you to pick out minor details like road signs and license plates in the resulting images.
Record in Full HD 1080p
ASUS RECO Classic Car Cam is powered by an Ambarella chipset and features the latest Omnivision CMOS sensor to let you record Full HD 1920 x 1080 resolution in-car videos at a smooth 30 frames per second.
The 140-degree wide-angle lens captures unobstructed views of the sides of the vehicle and the road ahead
Emergency record file protection
In the event of a collision, the built-in three-axis G-sensor triggers the emergency record function, saving a minute-long video (30 seconds prior to/after impact) and locking it down in a separate file so it won't be inadvertently deleted. There is also a manual emergency record button that allows you to save videos for every critical moment. You can save up to 10 emergency record clips without having to worry about recording over them.
Designed with road safety in mind
At speeds above 60km/h, ASUS RECO Classic Car Cam has a Lane Departure Warning System (LDWS) that gives you onscreen warnings and audio alerts if the vehicle veers outside road lane markings; while the Forward Collision Warning System (FCWS) lets you know if you're following too closely to the car ahead.
Speed camera detection
A GPS sensor notifies you of nearby speed cameras, and gives you audio and visual warnings as a reminder to maintain a safe driving speed*.
*only available in select territories
Easy setup
The compact ASUS RECO Classic Car Cam has a bracket mount which sticks on your windscreen, and comes with adhesive cable clips that effectively hide the cigarette lighter adapter cable.
No interference with other in-car devices
ASUS RECO Classic Car Cam does not interfere with other in-car systems and meets numerous global certification standards, including the China Compulsory Certificate mark (CCC Mark), CE mark, and the Taiwan Bureau of Standards, Metrology and Inspection.
  • Detailed Full HD in-car video recording
  • Capturing detailed video, day or night
  • Record in Full HD 1080p
  • 140-degree wide-angle lens
    The 140-degree wide-angle lens captures unobstructed views of the sides of the vehicle and the road ahead.
  • Emergency record file protection
  • Designed with road safety in mind
  • Easy setup
ASUS RECO Classic - dashboard camera
Dashboard camera - 1080p - widescreen
Memory Card Slot
microSD card
Image Processor
Ambarella
Sensors
G-sensor
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens f/2.0
Focus Adjustment
Focus free
Display
LCD display - 2"
Incident Detection
G-Sensor
Supported Battery
1 x (included)
Sensor Qty
1 CMOS
Widescreen Video Capture
Optical Sensor Type
CMOS
Frame Rate (Max Resolution)
30 fps
Image Processor
Ambarella
HDR Mode
Auto HDR mode
Sensors
G-sensor
Digital Video Format
H.264, MOV
1920 x 1080
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Focus Adjustment
Focus free
Max View Angle
140 degree(s)
Additional Features
Additional Features
Audio recording, built-in speaker, date/time stamp
Dashboard Camera Features
Incident Detection
G-Sensor
Lane Departure Warning System, Forward Collision Warning System
Display
2" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Car power adapter, camera mounting kit, adhesive mount
Battery Type
Integrated
Details
1 x (included)
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Memory Card Max Supported Size
64 GB
60 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BSVZ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BSVZ C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.37
BSVZ C2G 5m Select High Speed HDMI with Ethernet In Stock £21.26
BSVZ C2G 10m Select High Speed HDMI with Ethernet In Stock £40.83
BSVZ C2G 15m Select High Speed HDMI with Ethernet In Stock £55.31
BSVZ C2G Pro HDMI to VGA Converter In Stock £50.99
BSVZ C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
