Your basket is empty
Asus Radeon R7 360 OC 2GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: C0V8WS00 Mfr#: R7360-OC-2GD5-V2
ASUS R7 360 is a super-cool graphics card with pumped gaming performance, perfected manufacturing, and strong fortification for extreme reliability and longevity. Powered by the advanced graphics-processing units (GPUs), this graphics card, packed with ASUS technologies, including dual-fan design, delivers greater air flow and quieter performance. This model also has AUTO-EXTREME technology with Super Alloy Power II for aerospace-grade quality and reliability, plus GPU Tweak II for intuitive performance tweaking.
ASUS R7360-OC-2GD5-V2 - graphics card - Radeon R7 360 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 360
2 GB GDDR5
Core Clock
1070 MHz
Effective Memory Clock
6 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
DVI-I (dual link) , DVI-D (dual link) , DisplayPort , HDMI
API Supported
OpenGL 4.4, DirectX 12
3.8 cm x 22 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 360
Core Clock
1070 MHz
Max Resolution
4096 x 2160
API Supported
Dual Slot Fan Cooler, Native HDMI, AMD Eyefinity Technology, Dual Fan Design, AMD CrossFireX Technology, FreeSync Technology, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6 GHz
Bus Width
128-bit
Additional Requirements
6 pin PCI Express power connector
150 Watt
Software Included
Display drivers, XSplit Gamecaster, ASUS GPU Tweak II, World of Warships invite code
3.8 cm
22 cm
11.1 cm
