Q87-based Thin Mini-ITX motherboard for DIY all-in-one (AIO) or ultra-slim systems
- New UEFI BIOS and EZ Mode: Friendlier, easier, and more intuitive with helpful info added
- USB 3.0 BOOST (UASP Support): 170% faster transfer speeds than traditional USB 3.0
- Network iControl: Real-time network bandwidth management
- Fan Xpert 2: Comprehensive controls for the perfect cool and quiet balance
- CrashFree BIOS 3: Restore corrupted BIOS data from USB storage
- AI Suite 3: One-stop access to innovative ASUS features
Build slim. Build with Q87T
Want to build a DIY PC without the depth? Then you need Q87T - the first Thin Mini-ITX motherboard from ASUS. Measuring less than 2.5cm tall and with a built-in connector for external DC power, it is the perfect choice for all-in-one (AIO) PCs and other slimline builds. Building `thin' is simpler than you might think.
New UEFI BIOS - friendlier and more Intuitive: Exclusive EZ Mode adds useful info to become even easier
Media-renowned UEFI BIOS from ASUS provides the smoothest mouse-controlled graphical BIOS, and now features more intuitive functions to quickly take you to favorite BIOS pages and frequently-accessed settings through custom shortcuts. You can even write quick notes in-BIOS for future reference, view an activity log of setting changes and modifications, and rename SATA ports. EZ Mode has a whole new look, upgraded with extra-friendly capabilities like detailed fan controls, XMP profile settings, SATA information, and fast clock adjustment. Together, these perfect your BIOS experience.
Exclusive EZ mode adds useful info to become even easier
Media-renowned UEFI BIOS from ASUS provides the smoothest mouse-controlled graphical BIOS, and now features more intuitive functions to quickly take you to favorite BIOS pages and frequently-accessed settings through custom shortcuts. You can even write quick notes in-BIOS for future reference, view an activity log of setting changes and modifications, and rename SATA ports. EZ Mode has a whole new look, upgraded with extra-friendly capabilities like detailed fan controls, XMP profile settings, SATA information, and fast clock adjustment. Together, these perfect your BIOS experience. -
ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol) in Windows 8. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to already fast USB 3.0 performance. ASUS software automatically accelerates data rates for compatible USB 3.0 peripherals without any user interaction. -
ASUS AI Suite 3 offers a brand new user experience through a clearer and more attractive interface with support for larger monitors. It consolidates all exclusive ASUS features into one simple-to-use package, allowing you to supervise overclocking, energy consumption, fan speeds, voltages and more. This all-in-one app offers diverse and easy to use functionality, with no need to switch back and forth between different utilities. -
Multiple startup options
Thanks to ASUS Windows 8 hardware optimization, ASUS Boot Setting provides better flexibility in customizing your PCs startup process. You can shorten system boot-up time to 2-seconds for a smoother user experience under Windows 8, and even previous versions of Windows. Also, you can enter the BIOS directly with one click through a user-friendly interface, and quickly select your preferred system boot up method: either get to the OS in seconds or opt for regular boot up. Whatever your choice, settings are saved and persistent, with no need to choose every time you power on. -
Discover future visual experiences
Following up on popular 1080p full HD, 4K Ultra HD is the next big thing, and you're ready for the upgrade thanks to integrated graphics that natively support up to 4096 x 2160 via HDMI or DisplayPort. That's four times the pixel count of 1080p (1920 x 1080), offering incredible visual clarity, detail, and realism.
- ASUS Q87T - motherboard - mini ITX - LGA1150 Socket - Q87
- Product Type
- Motherboard - mini ITX
- Chipset Type
- Intel Q87
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 16 GB
- RAM Supported
- 2 SO-DIMM slots - DDR3
- Storage Ports
- 5 x SATA-600 (RAID)
- USB / FireWire Ports
- 4 x USB 3.0 + (2 x USB 3.0 + 5 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Chipset Type
- Intel Q87
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 16 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Dual channel memory architecture
Audio
- Audio Codec
- Realtek ALC887-VD
- High Definition Audio
LAN
- Network Controller
- Intel I217LM / Realtek 8111G
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x SO-DIMM 204-pin , 1 x PCIe 3.0 x4 , 1 x Mini PCIe 2.0 (full-length, auto turn-off, if Mini-SATA slot occupied) , 1 x Mini PCIe 2.0 (half-length)
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin SATA, 1 x mSATA - 5 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 4 x USB 3.0 , 1 x DisplayPort , 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
- Internal Interfaces
- 2 x USB 3.0 - header , 5 x USB 2.0 - header , 1 x serial - header , 1 x audio - header , 1 x LVDS - header
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, UEFI BIOS
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR), wake on PME
- Hardware Features
- Jack retasking, Trusted Platform Module (TPM), ESD Guards, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS Fan Xpert, Intel Turbo Boost Technology 2.0, Conductive Polymer Capacitors, USB 3.0 Boost, ASUS Network iControl, 4K Ultra HD ready, ASUS Boot Setting, Preboot eXecution Environment (PXE), Clear CMOS Button, anti-pop function
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Charger, ASUS Update, ASUS AI Suite III
- Plug and Play, ACPI 2.0a, ErP Ready
- 17 cm
- 17 cm
