Full-featured, thin-client mini-ITX Q170 choice for DIY AIO PCs or ultra-slim systems, with 5X Protection II for dependable stability, DDR4 SO-DIMM support and EZ Flash 3 quick BIOS updates.
- 5X Protection II – Advanced hardware safeguards for all-round protection
- Support 12V and 19V input via back-panel DC-in jack
- AI Suite 3:One-stop access to innovative ASUS features
- Fan Xpert:Dedicated CPU and case fan controls
Advanced Hardware Safeguards
Industry-leading 5X Protection II employs the finest components, excellent circuit design, and exacting standards to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build — the result of decades of engineering experience from the world's leading motherboard brand.
LANGuard
Pumped-up throughput. 2.5X higher surge tolerance.
ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors ensuring a more reliable connection and better throughput, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
Overvoltage Protection
World-class circuit-protecting power design
An exclusive circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies.
DRAM Overcurrent Protection
Short-circuit damage prevention
Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected devices.
DIGI+ VRM
Precision control for stable power
ASUS-exclusive DIGI+ VRM intelligently delivers power to the processor based on real-time demands, reducing energy waste and improving system stability.
Stainless-Steel Back I/O
3X corrosion-resistance for greater durability
Corrosion-resistant stainless steel back I/O panels bonded with chromium oxide have a lifespan that's three times (3X) longer than ordinary panels.
DDR4 Support
Make your memory go faster
With DDR4, you'll accelerate memory frequencies up to an incredible to 2133MHz! And ASUS works with almost every DDR4 memory vendor, so you're assured the best compatibility.
Media-acclaimed UEFI BIOS
The smoothest, slickest mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, the EZ and Advanced Modes help you find your way, quickly and easily.
Ultrafast Transfer Speed
M.2
With x4 PCI Express 3.0/2.0 bandwidth, M.2 supports up to 32Gbit/s data-transfer speeds. It is the perfect choice for an operating system or application drive, making your whole PC or professional apps work as fast as possible.
Instant front-panel USB 3.0 Experience
We've put USB 3.0 right where you need it — four super-speed ports on the front panel. Experience data-transfer speeds up to 10X faster than USB 2.0 with instant plug-and-play connectivity, so no more back-breaking contortions in the hunt for hard-to-reach rear ports!
Optimized Cooling
Fan Xpert 2+
Advanced fan controls
- With onboard thermal detection and hardware-level 4-pin/3-pin PWM/DC mode, Fan Xpert 2+ makes sure every fan achieves the best balance of cooling performance and low noise!
- Auto-Tuning Mode: Scans and detects all fan characteristics for single-click customization.
- RPM Fixed Mode: Lowers noise levels to near-0dB silence, allowing to you fix the fan speed.
AI Suite 3
ASUS AI Suite 3 offers a brand-new user experience through a clearer and more attractive interface with support for larger monitors. It consolidates all exclusive ASUS features into one simple-to-use package, allowing you to supervise overclocking, energy consumption, fan speeds, voltages and more. This all-in-one app offers diverse and easy to use functionality, with no need to switch back and forth between different utilities.
Intel CPU and chipset features
Intel® Q170 Chipset
The Intel® Q170 is a single-chipset design that supports 6th-generation Intel LGA1151 Core™ i7 / Core i5 / Core i3 / Pentium® / Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. It natively supports up to 10 USB 3.0, six SATA 6Gbit/s ports, and PCIe 3.0 lane speed support for faster data retrieval. Intel® Q170 chipset also supports iGPU functionality, so you'll enjoy the very latest Intel integrated graphics performance.
Ready for 6th-generation Intel LGA1151 Core i7/Core i5/Core i3/Pentium/Celeron processors
This motherboard supports 6th-generation Intel Core i7/i5/i3/Pentium/Celeron processors in the LGA1151 package, with graphics, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, two-channel (4-DIMM) DDR4 memory and 16 PCI Express 3.0/2.0 lanes for great graphics performance.
Intel® vPro
Intel® vPro™ Technology allows IT organizations to remotely manage corporate PCs, even when they are powered off or with non-functional operating systems. It features Intel® Active Management Technology and offers a lighter-weight form of virtualization to audit all Intel® AMT-based platforms in a networked environment. PCs with Intel® vPro™ Technology allow IT departments to remotely retrieve assets and hardware/software inventories, contain security threats, resolve system problems, and increase the uptime of desktops with lower maintenance costs.
- ASUS Q170T - motherboard - Thin mini ITX - LGA1151 Socket - Q170
- Product Type
- Motherboard - Thin mini ITX
- Chipset Type
- Intel Q170
- Compatibility
- Intel vPro
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 32 GB
- RAM Supported
- 2 SO-DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 4 x USB 3.0 + (2 x USB 3.0 + 5 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Chipset Type
- Intel Q170
- Compatibility
- Intel vPro
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- Realtek ALC887-VD
- High Definition Audio
LAN
- Network Controller
- Intel I219LM / Realtek RTL8111H
- Network Interfaces
- Expansion Slots
- 1 x CPU , 2 x SO-DIMM 260-pin , 1 x M.2 socket
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 4 x 7pin SATA, 1 x M.2
- 2 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 1 x DisplayPort , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x HDMI
- Internal Interfaces
- 5 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x LVDS - header , 1 x Embedded DisplayPort (eDP) - header , 1 x speaker - header
- Power Connectors
- DC-in power connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Conductive Polymer Capacitors, Intel Small Business Advantage support, ASUS Enhanced DRAM Overcurrent Protection, ASUS Stainless Steel Back I/O, LANGuard, ASUS 5X Protection II, overvoltage protection
- Included Accessories
- I/O back plate, 2 x M.2 screws, Thin mini ITX I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Mobo Connect, Media Streamer, ASUS EZ Flash 3
- Plug and Play, ACPI 5.0
- 17 cm
- 17 cm
