Asus Pro 15 R540LA Core i3-5005 4GB 256GB SSD 15.6" Windows 10 Pro
Quicklinx: F30KWS00 Mfr#: R540LA-DM974R
Display Size: 15.6in
Processor Model: I3-5005U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 256GB
  • Core i3
  • Bluetooth 4.0
  • IEEE 802.11n
£341.73 ex VAT
£410.07 inc VAT
The ASUS R540 series is powered by high-performance processors to give you smooth and responsive computing performance. With amazing graphics and enhanced onboard memory controller, it is an ideal daily computing platform.
  • Faster and easier connections with USB Type-C
    The reversible USB Type-C port makes connecting devices much easier and gives you super-fast USB 3.1 Gen 1 speeds! Its compact port design even helps preserve R540's thin dimensions. The R540 still carries the traditional USB 3.0 and USB 2.0 ports to ensure compatibility with all your USB devices.
  • Expansive audio, tuned by experts
    A mixture of hardware, software, and tuning, SonicMaster was developed with the clear goal of giving you a great notebook PC audio. A professional codec ensures precise sound performance while an optimized amplifier, larger speakers and resonance chambers deliver powerful audio output and deeper bass.
  • Crafted speaker design for greater sound
    The R540 features round speakers that maximize every cubic millimeter of available chassis space to give you better low frequency performance and reduced noise. The extra-large chamber provides superior bass and amazing sound clarity.
  • Elegant finished, lightweight design
    ASUS R540 has a solid and lightweight chassis that is ideal to take with you when you're out and about. Its premium brushed finish turns heads and makes sure that you stand out from the crowd.
  • Enjoy a world of color with ASUS Splendid technology
    To ensure only great images, ASUS Splendid technology has color temperature correction to reproduce richer, deeper colors. It features four visuals modes which can be accessed with a single click.
  • Protect your eyes with ASUS Eye Care
    Most LED panels emit blue light - the main cause of macular degeneration and retinal problems. ASUS Eye Care mode effectively reduces blue light levels to make reading comfortable, and to protect you from potential eye fatigue and other ailments.
  • Intuitive ASUS Smart Gesture input
    ASUS Smart Gesture technology utilizes an intelligent combination of hardware and software optimization to give you precise input. Sophisticated smartphone touchscreen production methods result in a highly sensitive touchpad that allows you to pinch-zoom in and out, or scroll through images and webpages with ease.
  • Stays cool, even after hours of use
    ASUS IceCool technology gives this laptop an internal design that addresses uncomfortable heating issues by preventing heat build-up under the palm rest. This exclusive internal layout places heat producing components away from you, and when combined with exceptional cooling from the heat pipes and vents, ensures you stay comfortable even after long hours of use.
ASUS R540LA DM974R - 15.6" - Core i3 5005U - 4 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i3 (5th Gen) 5005U / 2 GHz / 3 MB Cache
4 GB DDR3L
Storage
256 GB SSD
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 5500
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
3-cell
Chocolate black IMR with hairline (LCD cover), gold IMR with hairline (top)
38.1 cm x 25.2 cm x 2.72 cm
2 kg
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
4 GB
Max RAM Supported
8 GB
DDR3L SDRAM
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD - (2.5") SATA 6Gb/s
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare, 45% NTSC colour gamut
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Speaker, microphone
Audio Features
ASUS SonicMaster
Input
Keyboard, touchpad
Communications
Wireless
Network Interface
10/100 Ethernet
3-cell Lithium Ion
33 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Headphone/microphone combo jack , VGA , HDMI , LAN , USB 2.0 , USB 3.0 , USB-C Gen 1
Memory Card Reader
3 in 1 (SD Card, SDHC Card, SDXC Card)
System password, hard drive password, ASUS IceCool design
Power adapter
2 kg
Software applications
Asus Pro 15 R540LA Core i3-5005 4GB 256GB SSD 15.6 Bundle deal on Asus Pro 15 R540LA Core i3-5005 4GB 256GB SSD 15.6" Windows 10 Pro
£524.89
saving £8.33
£440.90
Optical Storage: None
Graphics: Intel HD Graphics 5500
Hard Drive Type: SSD
Type: Laptop
Brand: Asus
Price Range Ex VAT: 300 - 500
