Asus Pro 14 R410UA Core i7-7500 8GB 256GB SSD 14" Windows 10 Pro
Quicklinx: F30RWS00 Mfr#: R410UA-EB530R
Display Size: 14in
Processor Model: I7-7500U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
£495.52 ex VAT
£594.62 inc VAT
Marketing description is not available.
  • NanoEdge Display
    Offering a thin 7.1mm bezel and 73.8% screen-to-body ratio, the NanoEdge display on R410 provides you with more screen area for super immersive viewing.
  • Visuals
    ASUS exclusive technologies ensure the very best visual experience. ASUS Splendid visual optimisation technology provides high quality visuals for any type of content. It features four display modes: Normal mode is ideal for daily tasks; Vivid mode optimises contrast to deliver stunning photos and video; Eye Care mode reduces blue-light levels to ease eye strain; and Manual mode allows for personalised colour adjustments. ASUS Tru2Life Video technology intelligently optimises each pixel in the video frame to increase sharpness and contrast by 150% so youll enjoy the best possible image quality.
  • Audio
    ASUS SonicMaster and ASUS Audio Wizard provide the perfect combination of hardware, software and audio tuning orchestrated with the goal of delivering to you, the very best audio experience. ASUS SonicMaster employs a professional-grade codec to ensure precise audio encoding and decoding, and uses amplifiers, large speakers and resonance chambers that are perfectly-suited for your specific device. ASUS Audio Wizard is a powerful software suite that makes it easy to achieve the ideal audio balance for any type of content. It also offers manual settings options, so you can take full control of your audio mix for truly immersive sound.
  • IceCool
    ASUS IceCool technology uses smart fan control, thin heat pipes and clever design to create an efficient cooling system that keeps the average palm rest surface temperature below 36°C, lower than body temperature, so you get robust cooling performance and a comfortable user experience.
  • Battery
    R410 features a 3x the lifespan of standard lithium-ion batteries, with a battery life of up to 6 hours. What's more, with ASUS fast-charge technology, a low battery can be charged to 60 percent in just 49 minutes.
ASUS R410UA EB530R - 14" - Core i7 7500U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (7th Gen) 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache
8 GB DDR4
Storage
256 GB SSD
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Integrated Webcam
802.11ac, Bluetooth 4.1
3-cell
Security
Firmware Trusted Platform Module (TPM) Security Chip, fingerprint reader
Starry grey IMR with hairline (LCD cover), starry grey IMR with dot/fabric pattern (top)
32.8 cm x 24.6 cm x 2.29 cm
1.55 kg
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB
Max RAM Supported
16 GB
DDR4 SDRAM
Slots Qty
2
Storage
Main Storage
256 GB SSD - (M.2) SATA 6Gb/s
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare, 45% NTSC colour gamut
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Speaker, microphone
Audio Features
ASUS Bang & Olufsen ICEpower
Input
Keyboard, touchpad
Communications
Wireless
3-cell Lithium Ion
33 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.0 , USB 2.0 , HDMI
Memory Card Reader
Yes (microSD)
Security
System password
Power adapter
1.55 kg
Display Size: 14in
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: Asus
Price Range Ex VAT: 300 - 500
