NanoEdge Display
Offering a thin 7.1mm bezel and 73.8% screen-to-body ratio, the NanoEdge display on R410 provides you with more screen area for super immersive viewing. -
Visuals
ASUS exclusive technologies ensure the very best visual experience. ASUS Splendid visual optimisation technology provides high quality visuals for any type of content. It features four display modes: Normal mode is ideal for daily tasks; Vivid mode optimises contrast to deliver stunning photos and video; Eye Care mode reduces blue-light levels to ease eye strain; and Manual mode allows for personalised colour adjustments. ASUS Tru2Life Video technology intelligently optimises each pixel in the video frame to increase sharpness and contrast by 150% so youll enjoy the best possible image quality. -
Audio
ASUS SonicMaster and ASUS Audio Wizard provide the perfect combination of hardware, software and audio tuning orchestrated with the goal of delivering to you, the very best audio experience. ASUS SonicMaster employs a professional-grade codec to ensure precise audio encoding and decoding, and uses amplifiers, large speakers and resonance chambers that are perfectly-suited for your specific device. ASUS Audio Wizard is a powerful software suite that makes it easy to achieve the ideal audio balance for any type of content. It also offers manual settings options, so you can take full control of your audio mix for truly immersive sound. -
IceCool
ASUS IceCool technology uses smart fan control, thin heat pipes and clever design to create an efficient cooling system that keeps the average palm rest surface temperature below 36°C, lower than body temperature, so you get robust cooling performance and a comfortable user experience. -
R410 features a 3x the lifespan of standard lithium-ion batteries, with a battery life of up to 6 hours. What's more, with ASUS fast-charge technology, a low battery can be charged to 60 percent in just 49 minutes.
- ASUS R410UA EB381R - 14" - Core i5 8250U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 256 GB SSD
- Optical Drive
- No optical drive
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Integrated Webcam
- Networking
- 802.11ac, Bluetooth 4.1
- Battery
- 3-cell
- Security
- Firmware Trusted Platform Module (TPM) Security Chip, fingerprint reader
- Starry grey IMR with hairline (LCD cover), starry grey IMR with dot/fabric pattern (top)
- 32.8 cm x 24.6 cm x 2.29 cm
- 1.55 kg
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD - (M.2) SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare, 45% NTSC colour gamut
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Sound
- Speaker, microphone
- Audio Features
- ASUS Bang & Olufsen ICEpower
Input
- Keyboard, touchpad
Communications
- Wireless
- Technology
- 3-cell Lithium Ion
- Capacity
- 33 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- Headphone/microphone combo jack , USB 3.0 , USB 2.0 , HDMI
- Memory Card Reader
- Yes (microSD)
- Security
- System password
- Included Accessories
- Power adapter
- 1.55 kg
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.49 | in stock |
£636.22
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£552.23
