ASUS PRIME Z270M-Plus LGA1151 DDR4 HDMI DVI VGA M.2 USB 3.1 Z270 mATX Motherboard
- Maximize your connectivity and speed with integrated Dual M.2 slots, IntelĀ® Optaneā¢ Memory compatibility and a rear USB 3.1 Type C connection
- 5X Protection III Hardware-level safeguards provide component longevity and reliability
- FanXpert 4 Core delivers advanced fan control for dynamic cooling
- Dual Patent-pending SafeSlot Core fortified PCIe slot prevents damage caused by heavyweight GPUs
- On-board 3D-printing mountsfor creating unique designs on your customized build
- ASUS PRIME Z270M-PLUS - motherboard - micro ATX - LGA1151 Socket - Z270
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel Z270
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600 (RAID), 2 x M.2
- USB / FireWire Ports
- 1 x USB-C + 2 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel Z270
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 - RAID 0
- RAID Features
- Intel Smart Response Technology
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x DVI-D , 1 x VGA , 1 x USB-C , 2 x USB 2.0
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Fanless Design Heatsink, AMD CrossFireX technology support, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), Clear CMOS Button, ASUS Stainless Steel Back I/O, ASUS O.C. Tuner, LANGuard, ASUS Overvoltage Protection, Lighting Control, Intel Optane Memory Ready, ASUS 5X Protection III, ASUS SafeSlot Core, ASUS Fan Xpert 4 Core
- Included Accessories
- 1 x M.2 screw, I/O back cover
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), ASUS EZ Flash 3
- Plug and Play
- 24.38 cm
- 23.88 cm
