Asus PRIME X370-PRO AMD X370 AM4 DDR4 M.2 USB3.1 PCIe3.0 ATX
Quicklinx: CR1KWS00 Mfr#: PRIME X370-PRO
Processor Socket: Socket AM4
Chipset: AMD X370
Graphics: Graphics adapter (CPU required)
Form Factor: ATX
Memory Support: DDR4 SDRAM
Hurry, only 3 left in stock!
£104.67 ex VAT
£125.60 inc VAT
AMD AM4 ATX motherboard with Aura Sync, DDR4 3200MHz, 32Gb/s M.2, DP/HDMI, SATA 6GB/s, USB 3.1
  • 5-Way Optimization: One-click system-wide tuning that now also senses GPU temperatures to ensure cooler gaming
  • ASUS Aura Sync – World’s first synced RGB lighting with easy controls to orchestrate Aura Sync-capable hardware
  • Refined Audio: Realtek ALC1220 codec provides pristine and powerful audio quality
  • ASUS SafeSlot: Patent-pending PCIe with enhanced retention and shearing resistance
  • 5X Protection III: Multiple hardware safeguards to protect components from damage by power or electrical surges
ASUS Prime is the next evolution of the ASUS motherboard, born of a pedigree that stretches back to 1989. Our team of world-class engineers are passionate about empowering everyone to enjoy the benefits of customization and tuning, and the driving force behind the development of Prime is to make advanced enthusiast controls easily accessible — maximizing performance, stability and compatibility for the very best DIY PC experiences. Simply stated: it's time for Prime.
One-click Overclock and Cooling
Get performance, efficiency, digital power, fan control, networking and audio tuning - all tailored with just one click.
ASUS 5-Way Optimization makes your PC smart. It dynamically optimizes essential aspects of your system based on real-time usage — so you get superb CPU performance, everyday energy savings, ultra-stable digital power, cool and quiet fans, and now networking and audio settings that are tailored to your apps. In short, 5-Way ASUS Optimization ensures that your PC is perfect for gaming, entertainment and productivity!
• Games run swiftly and smoothly with high performance, prioritized bandwidth and vivid sound.
• Fans stay whisper-quiet for everyday computing, and ensure extreme cooling efficiency when gaming.
• Stutter is eliminated for smooth-running apps, even under heavy loading.
• Energy=-conserving design saves your money.
DDR4 Support
With DDR4, you'll accelerate memory frequencies up to an incredible to 3200MHz! And ASUS works with almost every DDR4 memory vendor, so you're assured the best compatibility
Media-acclaimed UEFI BIOS
The smoothest, slickest mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, EZ and Advanced modes help you find your way, quickly and easily.
Outshine The Competition
ASUS Aura Sync technology for distinctive lighting effects
Aura Sync takes RGB lighting beyond the checkbox, combining and controlling the LEDs of your Aura-enabled products from a single application — so you can achieve perfect, synchronized lighting harmony. Aura lets you sync light effects across your graphics card, Prime X370-Pro motherboard, and an ever-growing portfolio of Aura-enabled products.
ASUS PRIME X370-PRO - motherboard - ATX - Socket AM4 - AMD X370
Motherboard - ATX
Chipset Type
AMD X370
Processor Socket
1 x Socket AM4
Compatible Processors
Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
USB 3.0, USB 3.1, USB-C 1 x USB-C + 2 x USB 3.1 + 5 x USB 3.0 + (1 x USB-C + 2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD X370
Processor Socket
Socket AM4
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 2933 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
2 GB
Audio
Audio Codec
Realtek ALCS1220A
High Definition Audio
LAN
Network Controller
Intel I211-AT
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16/x8 mode (with AMD Ryzen CPU); slot not works with AMD 7th Generation A-series/Athlon CPU) , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 3.0 x16 (x8 mode)
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 5 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 1 x USB-C , 2 x USB 3.1 , 1 x HDMI , 1 x DisplayPort , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header , 1 x USB-C - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS O.C. Profile, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.1 support
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, NVIDIA 2-way SLI Technology Support, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Fanless Design Heatsink, AMD 3-way CrossFireX technology support, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, Turbo LAN, Dual Intelligent Processors 5, LANGuard, ASUS Overvoltage Protection, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS 5X Protection III, ASUS SafeSlot Core
1 x M.2 screw, I/O back cover
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS Turbo App, PC Cleaner
Plug and Play
30.5 cm
24.4 cm
Chipset: AMD X370
Form Factor: ATX
Brand: Asus
Stock Status: Clearance
Price Range Ex VAT: 100 - 150
