Asus PRIME X299-A Intel X299 S2066 DDR4 M.2 USB3.1 ATX
Quicklinx: CYNNWS00 Mfr#: PRIME X299-A
Processor Socket: LGA2066 Socket
Chipset: Intel X299 Express
Graphics: None
Form Factor: ATX
Memory Support: DDR4 SDRAM
£235.95 ex VAT
£283.14 inc VAT
Intel LGA 2066 ATX motherboard with M.2 Heatsink, DDR4 4133MHz, Dual M.2, Intel VROC support, SATA 6Gb/s, Front-panel USB 3.1 Gen 2 connector
  • 5-Way Optimization: One-click, system-wide tuning, delivering optimized overclocks and intelligent cooling for CPU or GPU-intensive tasks.
  • Industry-leading cooling options: Comprehensive controls for fans and water pumps, via Fan Xpert 4 software or the acclaimed ASUS UEFI.
  • M.2 heatsink: Ultra-efficient heatsink reduces M.2 SSD temperatures by up to 20°C for unthrottled SSD storage speeds and enhanced reliability.
  • Aura Sync: Controllable onboard RGB lighting that’s easily synced with an ever-growing portfolio of Aura-capable hardware.
ASUS PRIME X299-A - motherboard - ATX - LGA2066 Socket - X299
Motherboard - ATX
Chipset Type
Intel X299 Express
Processor Socket
1 x LGA2066 Socket
Compatible Processors
Core X
Max RAM Size
128 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
3-year warranty
Motherboard - ATX
Chipset Type
Intel X299 Express
Processor Socket
LGA2066 Socket
Max Processors Qty
1
Core X
Supported RAM
Max Size
128 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 3600 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Audio
Audio Codec
Realtek ALCS1220A
DTS Connect, High Definition Audio, DTS Headphone:X
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 (44-lane CPU (x16, x16/x16, x16/x16/x8 modes), 28-lane CPU (x16, x16/x8, x16/x8/x1 modes), 16-lane CPU (x16, x8/x8, x8/x8/x1 modes)) , 2 x PCIe 3.0 x4 , 1 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
RAID Features
Intel Smart Response Technology
1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x TOSLINK , 1 x USB 3.1 Gen 2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x USB-C Gen2
Internal Interfaces
2 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x USB 3.1 Gen 2 - header , 1 x Thunderbolt - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, USB BIOS Flashback, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, MemOK!, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Smart Response Technology, Q-Code, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, Onboard Button, Preboot eXecution Environment (PXE), anti-pop function, Turbo LAN, Dual Intelligent Processors 5, LANGuard, ASUS Crystal Sound 3, ASUS PRO Clock Technology, AURA RGB Lighting Control, ASUS Fan Xpert 4, Intel Turbo Boost Technology 3.0, 3D printing friendly, Intel Optane Memory Ready, ASUS 5X Protection III, Intel VROC support, M.2 heatsink
I/O back plate, 1 x M.2 screw, vertical M.2 bracket set
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), ASUS Turbo Core App
30.5 cm
24.4 cm
Limited warranty - 3 years
Graphics: None
Form Factor: ATX
Brand: Asus
Price Range Ex VAT: 150 - 300
