Product
Asus PRIME H270-PLUS Intel H270 S1151 DDR4 M.2 USB3.0 ATX
Quicklinx: CLYCWS00 Mfr#: PRIME H270-PLUS
Processor Socket: LGA1151 Socket
Chipset: Intel H270
Graphics: Graphics adapter (CPU required)
Form Factor: ATX
Memory Support: DDR4 SDRAM
11 in stock
£69.94 ex VAT
£83.92 inc VAT
  • 5X Protection III: Multiple hardware safeguards for all-round protection.
  • LED illumination: Lighting control for PCIe slot.
  • Dual native M.2 support: Lightning-fast storage speeds.
  • IntelĀ® Optaneā„¢ memory ready: Exploit the latest high-speed storage technology.
  • Fortified PCIe slot prevents damage
    SafeSlot Core is the ASUS-exclusive PCIe slot. Featuring a fortified design that's anchored to the motherboard by a special hook, Safeslot Core provides 1.6x stronger retention and 1.3x greater shearing resistance than standard expansion slots.
  • Pumped-up throughput, 2.5x higher surge tolerance
    ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors to ensure a more reliable connection and better throughput, plus electrostatically guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
  • World-class circuit-protecting power design
    An exclusive circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies.
  • Electrostatic discharge protection
    ASUS ESD Guards prevent damage from electrostatic discharge, up to +/- 10 kV for air discharge and +/- 6 kV for contact discharge, arranged in an active-protective-circuit design that prolongs the life of components.
  • Top-to-bottom reliability
    ASUS motherboards have superb endurance. They verify this by subjecting every board to more than 8,000 hours of stringent tests. A barrage of burn-in, environmental, compatibility, software and safety tests confirm that their motherboards are exceptionally robust. It also shows that ASUS reliability surpasses industry standards, ensuring that every component is designed to function flawlessly in any environment.
ASUS PRIME H270-PLUS - motherboard - ATX - LGA1151 Socket - H270
Motherboard - ATX
Chipset Type
Intel H270
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
USB 3.0 4 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel H270
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x4 mode) , 4 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2
1 x HDMI , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x PS/2 mouse , 4 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x DVI-D
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header , 2 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, AMD CrossFireX technology support, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 2+, LANGuard, ASUS Overvoltage Protection, Lighting Control, Intel Optane Memory Ready, ASUS 5X Protection III, ASUS SafeSlot Core
I/O back cover, 2 x M.2 screws
2 x Serial ATA cable
Software Included
ASUS AI Charger, ASUS AI Suite III
Plug and Play
Chipset: Intel H270
Form Factor: ATX
Brand: Asus
Price Range Ex VAT: 50 - 100
