Asus PRIME B350M-E AMD B350 AM4 DDR4 M.2 USB3.1 mATX
Quicklinx: CXHPWS00 Mfr#: PRIME B350M-E
ASUS Prime is the next evolution of the ASUS motherboard, born of a pedigree that stretches back to 1989. ASUS team of world-class engineers is passionate about empowering everyone to enjoy the benefits of customization and tuning, and the driving force behind the development of Prime is to make advanced enthusiast controls easily accessible - maximizing performance, stability and compatibility for the very best DIY PC experiences. Simply stated: it's time for Prime.
  • Protect your graphics card investment
    SafeSlot is the PCIe slot reinvented by ASUS and engineered to provide superior retention and shearing resistance. Manufactured in a single step using an insert-molding process to integrate the slot with fortifying metal support for an inherently stronger design, SafeSlot is then firmly anchored to the motherboard through additional solder points.
  • Built to last
    ASUS is a great motherboard manufacturer, renowned for unique Design Thinking approach. ASUS gives you the peace of mind of knowing that your motherboard is fit for all environments and applications.
  • 5X Protection III
    PRIME X370 motherboard is engineered with impressive 5X Protection III, employing the finest components, excellent circuit design, and exacting standards to guarantee the quality and long-term durability of your motherboard. That means exceptional protection and stability for your build.
  • Fortified PCIe slot prevents damage
    SafeSlot Core is the ASUS-exclusive PCIe slot. Featuring a fortified design that's anchored to the motherboard by a special hook, Safeslot Core provides 1.6x stronger retention and 1.3x greater shearing resistance than standard expansion slots.
  • LANGuard
    ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors to ensure a more reliable connection and better throughput, plus electrostatically guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
  • Overvoltage protection
    An exclusive circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies.
  • Precision control for stable power
    ASUS-exclusive DIGI+ VRM intelligently delivers power to the processor based on real-time demands, reducing energy waste and improving system stability.
  • Short-circuit damage prevention
    Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of your system and connected devices.
  • 3x corrosion-resistance for greater durability
    Corrosion-resistant stainless-steel back I/O panels bonded with chromium oxide have a longer lifespan.
  • Electrostatic discharge protection
    ASUS ESD Guards prevent damage from electrostatic discharge, up to +/- 10kV for air discharge and +/- 6kV for contact discharge, arranged in an active-protective-circuit design that prolongs the life of components.
ASUS PRIME B350M-E - motherboard - micro ATX - Socket AM4 - AMD B350
Motherboard - micro ATX
Chipset Type
AMD B350
Processor Socket
1 x Socket AM4
Compatible Processors
Athlon, A series, Ryzen 7 (supports 7th Generation A-series / Athlon)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
2 x USB 3.1 + 4 x USB 3.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD B350
Processor Socket
Socket AM4
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 2933 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
2 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (with AMD Ryzen CPU); x8 mode (with AMD 7th Generation A-series/Athlon CPU)) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 2 x USB 3.1 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse , 1 x VGA , 1 x DVI-D , 1 x HDMI , 1 x PS/2 keyboard
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header , 1 x audio - header , 1 x speaker - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ASUS EZ Flash 3, SMBIOS 3.0 support, ACPI 6.1 support
Hardware Features
ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, ASUS Fan Xpert, ASUS DIGI+ VRM, Fanless Design Heatsink, ASUS Stainless Steel Back I/O, LANGuard, ASUS Overvoltage Protection, Lighting Control, ASUS 5X Protection III, ASUS SafeSlot Core
1 x M.2 screw, I/O back cover
2 x Serial ATA cable
Software Included
ASUS AI Charger, ASUS AI Suite III
Plug and Play
22.6 cm
22.1 cm
