Asus PRIME B250M-PLUS Intel B250 S1151 DDR4 M.2 USBTypeC uATX
Quicklinx: CLY7WS00 Mfr#: PRIME B250M-PLUS
  • Maximize your connectivity and speed with integrated Dual M.2 slots with IntelĀ® Optaneā„¢ Memory compatibility, front panel USB 3.0 and a rear USB 3.1 Type C connection.
  • 5X Protection III Hardware-level safeguards provide component longevity and reliability.
  • FanXpert 2 PLUS delivers advanced fan control for dynamic cooling.
  • Dual Patent-pending SafeSlot Core fortified PCIe slot prevents damage caused by heavyweight GPUs.
  • On-board 3D-printing mounts for creating unique designs on your customized build.
  • SafeSlot Core
    SafeSlot Core is the ASUS-exclusive PCIe slot. Featuring a fortified design that's anchored to the motherboard by a special hook, Safeslot Core provides stronger retention and greater shearing resistance than standard expansion slots.
  • LANGuard
    ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors to ensure a more reliable connection and better throughput, plus electrostatically guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
  • Overvoltage protection
    An exclusive circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies.
  • Precision control for stable power
    ASUS-exclusive DIGI+ VRM intelligently delivers power to the processor based on real-time demands, reducing energy waste and improving system stability.
  • Short-circuit damage prevention
    Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of your system and connected devices.
  • Stainless-steel back I/O
    Corrosion-resistant stainless-steel back I/O panels bonded with chromium oxide have a lifespan that's three times longer than ordinary panels.
  • ESD Guards
    ASUS ESD Guards prevent damage from electrostatic discharge, up to +/- 10kV for air discharge and +/- 6kV for contact discharge, arranged in an active-protective-circuit design that prolongs the life of components.
ASUS PRIME B250M-PLUS - motherboard - micro ATX - LGA1151 Socket - B250
Motherboard - micro ATX
Chipset Type
Intel B250
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600, 2 x M.2
USB / FireWire Ports
1 x USB-C + 3 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel B250
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x4 mode) , 1 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x USB-C , 3 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI-D , 2 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
Sleep / Wake Up
Wake on LAN (WOL)
Hardware Features
Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, AMD CrossFireX technology support, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 2+, LANGuard, ASUS Overvoltage Protection, Lighting Control, Intel Optane Memory Ready, ASUS 5X Protection III, ASUS SafeSlot Core
I/O back cover, 2 x M.2 screws
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Flash 3
Plug and Play
24.4 cm
22.4 cm
