Product
Asus PRIME B250M-A Intel B250 S1151 DDR4 M.2 USB TypeC mATX
Quicklinx: CLY3WS00 Mfr#: PRIME B250M-A
Processor Socket: LGA1151 Socket
Chipset: Intel B250 Express
Graphics: Graphics adapter (CPU required)
Form Factor: Micro ATX
Memory Support: DDR4 SDRAM
Hurry, only 1 left in stock!
£46.77 ex VAT
£56.12 inc VAT
Express delivery Delivered on Tuesday
  • Maximize your connectivity and speed with integrated Dual M.2 slots with IntelĀ® Optaneā„¢ Memory compatibility and a rear USB 3.1 Type C connection.
  • 5X Protection III Hardware-level safeguards provide component longevity and reliability.
  • FanXpert 2 PLUS delivers advanced fan control with an integrated AIO pump header for dynamic cooling.
  • Dual Patent-pending SafeSlot Core fortified PCIe slot prevents damage caused by heavyweight GPUs.
  • On-board 3D-printing mounts for creating unique designs on your customized build.
  • SafeSlot Core
    SafeSlot Core is the ASUS-exclusive PCIe slot. Featuring a fortified design that's anchored to the motherboard by a special hook, Safeslot Core provides stronger retention and greater shearing resistance than standard expansion slots.
  • LANGuard
    ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors to ensure a more reliable connection and better throughput, plus electrostatically guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
  • Overvoltage protection
    An exclusive circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies.
  • Precision control for stable power
    ASUS-exclusive DIGI+ VRM intelligently delivers power to the processor based on real-time demands, reducing energy waste and improving system stability.
  • Short-circuit damage prevention
    Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of your system and connected devices.
  • Stainless-steel back I/O
    Corrosion-resistant stainless-steel back I/O panels bonded with chromium oxide have a lifespan that's three times longer than ordinary panels.
  • ESD Guards
    ASUS ESD Guards prevent damage from electrostatic discharge, up to +/- 10kV for air discharge and +/- 6kV for contact discharge, arranged in an active-protective-circuit design that prolongs the life of components.
ASUS PRIME B250M-A - motherboard - micro ATX - LGA1151 Socket - B250
Motherboard - micro ATX
Chipset Type
Intel B250 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600, 2 x M.2
USB / FireWire Ports
USB 3.0, USB-C 1 x USB-C + 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel B250 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse , 1 x VGA , 1 x DVI-D , 1 x HDMI , 1 x USB-C
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header , 1 x parallel - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 2+, LANGuard, ASUS Overvoltage Protection, ASUS 5X Protection III, ASUS SafeSlot Core
I/O back cover, 2 x M.2 screws
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), ASUS EZ Flash 3
Plug and Play
24.4 cm
20.6 cm
Brand: Asus
Stock Status: Clearance
Price Range Ex VAT: 0 - 50
