Asus PG27AQ ROG Swift 27" 3840x2160 4ms IPS HDMI Monitor
Quicklinx: C2V9WS00 Mfr#: PG27AQ
The ASUS ROG Swift PG27AQ gaming display is built for exceptional visuals in the professional gaming arena, and features a 4K/UHD resolution and IPS technology. Integrated NVIDIA G-SYNC technology synchronizes the display's refresh rate to the GPU to give you smooth visuals and lag-free gameplay.
  • ASUS-exclusive GameVisual technology
    ASUS GameVisual Technology has six pre-set display modes to optimize visuals for different types of content. This unique feature can be easily accessed through a hotkey or the On Screen Display (OSD) settings menu.
  • Super-narrow bezel design for seamless multi-display setups
    The ROG Swift PG27AQ's slim profile and super-narrow 6mm bezel makes it perfect for almost seamless multi-display setups so your eyes move swiftly from one monitor to another. It can also be VESA wall-mounted - an even easier way to have a multi-display gaming setup.
  • Flicker free technology
    Flicker free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other damaging effects when you're embroiled in long, drawn-out gaming sessions.
  • Ergonomic tilt, swivel, pivot, and height adjustable stand
    The ROG Swift PG27AQ is specially designed for marathon gaming sessions. It has an ergonomically-designed stand with tilt swivel, pivot, and height adjustment so you can always find that ideal viewing position whether you're on the couch or sitting on your bed.
ASUS ROG SWIFT PG27AQ - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
74 kWh
Power Consumption (On mode)
50 W
Adaptive-Sync Technology
NVIDIA G-SYNC
5-way joystick, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 24 Hz)
Pixel Pitch
0.155 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Gaming
Colour Support
1.074 billion colours (10-bit)
Colour Gamut
100% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
61.977 cm x 23.79 cm x 55.253 cm
7.2 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, RCM, CEL level 2, TUV Rheinland Low Blue Light Certification
3-year warranty
Display Type
Energy Class
Class C
74 kWh
Diagonal Size
27"
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.155 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
30 - 60 Hz
Horizontal Refresh Rate
50 - 133 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Trace Free Technology, ASUS GamePlus, super narrow frame, Low Blue Light Mode, Flicker Free technology, ASUS Smart Air Vent Design, ASUS GameVisual Technology
61.977 cm x 23.79 cm x 55.253 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
5-way joystick
DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , HDMI , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
Input Voltage
50 W
Power Consumption (Typical)
90 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 61.977 cm - depth: 6.598 cm - height: 36.296 cm , With stand - width: 61.977 cm - depth: 23.79 cm - height: 55.253 cm - weight: 7.2 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
